Old 08-28-2018, 02:58 PM   #1
Wavy
Drives: 2017 Toyota 86 SE 860 AT
Easy/Inexpensive Intake Sound Upgrade
Hey. I was wondering if there are any mods available for these engines to give me that nice deep intake suction/induction sound that you get from a Cold
Air Intake? I know it sounds like I answered my own question but I don't want to remove my bumper just to install a Perrin which looks and sounds great. I also know that intakes make negligible to no performance difference and is why I'm being real and saying I just want that deep engine bay sound. Anyone know any options that I can get that sweet sound without removing my bumper? Also, must be able to pass smog in CA.
(2017 Toyota 86 Auto)
Wavy is offline   Reply With Quote
Old 08-28-2018, 03:00 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
If you don't care about hp loss, any short ram intake will work and create a throatier sound. Quick easy install too.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-28-2018, 03:23 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
There's a set of I think, three different TRD kazoo whistles that you can use to replace the stock one mounted though the firewall for induction noises.
The twins already have CAI, as the intake is in the (relatively) cold air in front of the radiator.
Short runs that stop inside under the hood are quite the opposite of CAI.
Old 08-28-2018, 06:32 PM   #4
Wavy
Thanks! Yeah I’m considering short ram but I don’t plan on taking a power loss. Are you referring to the whole MAF sensor configuration issue?
Old 08-28-2018, 06:33 PM   #5
Wavy
I have seen these sound changers but I’m not looking for artificial noise being pumped into the cabin, I really like the induction sound in the engine bay.
Old 08-29-2018, 12:13 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Well you won't really get much louder than the intake noise that's already being pumped into the cabin. It's not even really artificial it's just a resonator thats plumbed into the area under the carpet. If you want to hear what it will sound like without the intake tube take the cigarette lighter plug cover and lift the carpet and put the cover into the hole you find in the footwell.
Old 08-29-2018, 01:39 AM   #7
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I did the sound tube delete + Supertek intake pipe and high flow filter in the stock box. The combination gives the deep throaty sounds. You can take it further and cut and cap the resonating chambers on the stock intake box and snorkel.
Other people have gone to home depot and grabbed the rubber pipe end caps and clamps for the sound tube and resonator removals.
Keep in mind that if plan to tune your car, aftermarket CAI can affect the maf readings differently.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 08-29-2018, 02:47 AM   #8
86MLR
86MLR's Avatar
You could replace the OEM rubber induction pipe with a alloy induction pipe.
I've seen a alloy intercooler pipe gerry rigged to fit, the breather was ducted into a 20mm? hole and a grommet was used to seal it.
4 hose clamps, 2 short silicon straights and "whalla", more induction noise
Ut aslo has the snorkel mod as well and no resonator, but that picks up only a small increase in noise, and only really heard when standing right at the front bumper.
I have a Mishimoto induction hose on mine to clean up the bay after removing the cabin noise maker, there was a slight increase of induction noise from that, sans the resonator as well as the snorkel mod.
You could always get a reinforced silicone straight to 90° pipe and drill and grommet that.
Just like a perrin or Mishimoto induction hose, but 1/3 the price.
I went with the Mishimoto one because alcohol and Ebay were involved in the matter.
Old 08-29-2018, 02:48 PM   #9
re-animator
just get any of the aftermarket intakes available for our cars and remove the top if it has one. The grimmspeed intake is around $300 (half that used) and has a lot of cone induction noise when you remove the cover. The hood keeps a lot of hot air from getting in anyway. The injen and K&N intakes are similarly cheap if you buy used. the AIRAID cai is one of the cheapest available for our cars and IMO it is one of the best sounding. Very deep and throaty.
re-animator is offline   Reply With Quote
Old 08-29-2018, 02:54 PM   #10
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
I would recommend against deleting the resonance chambers on the intake, they are part of the equation to keep the MAF happy.
Lincoln Logs is offline   Reply With Quote
The Following 5 Users Say Thank You to Lincoln Logs For This Useful Post:
Icecreamtruk (08-29-2018), SkyeHack (08-30-2018), SuperTom (09-01-2018), Tristor (09-14-2018), Ultramaroon (08-29-2018)
Old 08-29-2018, 03:39 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This is a very Easy/Inexpensive Intake Sound Upgrade!
Like a "lambo" @ 1:58
[ame]https://www.youtube.com/watch?v=AzUtrrMerU0[/ame]
I LIKE TIRES!
Old 08-30-2018, 09:02 AM   #12
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The Airraid CAI is one of the few that actually does lose power. Most make some power and if you do a little work around the bumper they don't suck in hot air. DSpoertMag found that the K&N and Injen intakes make the most power of all they tested.
guybo is offline   Reply With Quote
Old 08-30-2018, 10:21 AM   #13
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Snorkel Mod
/thread
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 08-30-2018, 10:45 AM   #14
Scala
Drives: 2018 BRZ tS
+1 but most people prefer to fool themselves.
Scala is offline   Reply With Quote
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
easy OEM Sound System Upgrade with DSP OnkelC Electronics | Audio | NAV | Infotainment 0 05-24-2015 10:12 AM
Easy in-cabin Subwoofer Upgrade JayNutter Electronics | Audio | NAV | Infotainment 17 12-17-2012 05:51 PM
Easy In-Cabin Subwoofer Upgrade (FR-S or BRZ) JayNutter Electronics | Audio | NAV | Infotainment 1 12-05-2012 12:41 PM
Inexpensive suggestion for better sound?? ngabdala Electronics | Audio | NAV | Infotainment 28 08-24-2012 01:05 PM
