Old 08-23-2018, 07:03 AM   #1
JIM THEO
Drives: BRZ 2018
MY18 EUDM BRZ read/write problem with Ecuflash
Own a MY18 EUM BRZ and while my Windows 10 laptop communicates with the ECU and reads MY, VIN etc, during handshake ECU cuts suddenly the connection, any suggestion please?
Problematic USB cable or what else?
By the time of trying to connect I used BRZ 13+ OEM reading method SubaruBRZ.
Someone told me it needs 20" inside the programm before I press twice cars start button and Ok in Ecuflash, could this be true?
And one more question for those that know well Ecuflash and Romraider.
I'd like, for various reasons, to copy maps from OFT or Wayne ROM to my own ROM (I don't care about FFS and LC).
As far as I know OFT V4.03 uses different Romraider def file than OEM wich means I CAN'T load similtaneously OFT def & my OEM ROM def in Romraider and copy maps from one ROM to the other as they are same call ID.
If I load my OEM Romraider def file it should read all the factory maps of OFT (or Wayne) ROM except those added later (FFS, LC) and I won't have problem with my edited OEM ROM if I copy other maps to it, am I correct?
JIM THEO is offline   Reply With Quote
Old 08-23-2018, 07:32 AM   #2
steve99
Drives: FT86
Make sure ignition full on, not just accessory
But engine not running
After you select read or write wait 10-15 seconds before clicking ok after you turn ignition full on with engine stopped
Make sure battery volts above 12 and switch all un necessay electrics like radio lights fans off before flashing or reading
If still no good are you sure car has not previously been tuned with ecutek or brzedit ?
Old 08-23-2018, 07:36 AM   #3
steve99
Drives: FT86
You making life hard by copying all the maps back to your stock rom, jist get an oft k00g or waynos k00g and use that, if you dont want lc or ffs jist disable them. Disabling lc ffs takes 1 minute, to copy all the maps and cgeck will take hours
Old 08-26-2018, 01:18 PM   #4
JIM THEO
Drives: BRZ 2018
Problem solved, a new shorter USB cable.
Just to say a BIG thanks to Steve99, he answered all my e-mails and helped me arrange every issue!
The Following User Says Thank You to JIM THEO For This Useful Post:
tomm.brz (08-26-2018)
Old 08-26-2018, 01:18 PM   #5
JIM THEO
Drives: BRZ 2018
MY18 Canadian Subaru owners you help please! JIM THEO Electronics | Audio | NAV | Infotainment 3 05-25-2018 02:09 AM
Noob question for backup camera on EUDM MY18 BRZ JIM THEO Electronics | Audio | NAV | Infotainment 2 05-05-2018 11:18 AM
Retuning BRZ with HKS tune, OFT and OS wont read or write Pro60modman Software Tuning 1 04-23-2018 06:15 AM
Ecuflash Problem Brz supercharged. laoboost Software Tuning 3 10-24-2017 09:38 AM
