#15 | |
Drives: 2019 BMW ///M4
Drove it some more and did some more hard braking. At low speeds below 30 MPH, I can slightly feel the rotor grooves in the brake pedal. At higher speeds 75-60, when I lightly brake, the car shudders but as I apply more pressure, the car does not shudder anymore. I think it's because the pad is lightly getting caught in the slots in the rotors and causing this issue. Maybe more time with it, it will wear the slots some more. Car still pulls to the right for some reason. Might be an issue with the caliper not having equal pressure on all 4 corners.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#16 |
Drives: Crapcan
Still doesn't sound right. I can feel the rotors through the pedal, but the car itself does not shudder. Do you have a bunch of pad stuck to the rotors from previous bed in attempts?
#17 |
Not that I can see or feel from touching it.
N1rve
#18 |
Update: Had the installer check out the install. Everything is installed correctly, but it seems like the rotors aren't balanced causing the vibration at high speeds. Will contact Wilwood on Monday.
N1rve
| The Following User Says Thank You to N1rve For This Useful Post: | Stang70Fastback (08-18-2018) |
#19 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Thanks for following-up! I wish more people would do that...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#20 |
So my vendor (installer/mechanic) has been going back and forth with Wilwood asking for replacement rotor rings or any other possibility without removing the rotors from the car and shipping it them and leaving the car out of commission for a few days and they are saying no. They are asking for the rotors to be shipped to be measured for run out or whatever. I think as a vendor like Wilwood, they should be fine with cross shipping rotors. Especially if it's vendor to vendor and not vendor to customer directly.
I convinced my vendor/installer to resurface the rotors and hopefully that would fix the issue. Going to attempt this Saturday. Ugh, cmon Wilwood...is it that difficult to ship your vendor a set of spare rotors to trouble shoot? So far my experience with Wilwood support..... terrible. I don't know if Brembo, StopTech or AP Racing would have a better support line if it's vendor to vendor.
N1rve
| Troubleshooting Idle | bfsnail | Forced Induction | 3 | 12-03-2016 06:05 PM |
| BRZ DRL Troubleshooting | MaximaZero | Issues | Warranty | Recalls / TSB | 2 | 11-17-2015 04:31 AM |
| Troubleshooting with a KW c38 | pgranberg11 | Forced Induction | 7 | 10-13-2015 08:05 AM |
| Need troubleshooting help. | Camop82 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-14-2013 02:16 AM |
| Start up troubleshooting. | Gost | Other Vehicles & General Automotive Discussions | 12 | 01-09-2011 06:45 PM |
