#15 |
I dunno, Leo. I've been keeping my mouth shut. Feel bad for the kid but that trunk lid is toast. Maybe longer bolts and spacers between the sheet and some creative bracing... Gets complicated quickly.
#16 |
Country Boy 4 Life
Yes, the trunk lid is FUBAR . Some creative efforts could save it though. Some welding, bodywork, and paint. Good as new... well not new. But it would be functional.
I LIKE TIRES! |
#17 |
That's about it, really.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Leonardo (08-14-2018) |
#18 |
Drives: C5, GT-86, '24 Colorado TrailBoss
too late but you have a 17' right? Could have bought the drambeenie risers for the stock wing
#19 | |
TRACKBREAD
No, that stuff sucks for structural applications. Real structural foam is literally rockhard when cured. Like you can hit it with a hammer. I agree that the proper way to install he wing is to use longer bolts and backing plates through the bracing rather than cutting large holes in the bracing. The trunk lid is already structurally ruined in those spots, so why not give the foam a shot? I'm willing to bet it does the job, I use this on composite airplanes, and BMW used a similar foam to reinforce their subframe mounting areas after it turned out they went too thin on the metal. |
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | Leonardo (08-14-2018), texastwurkt3am (08-14-2018) |
#20 |
Drives: '17 PP BRZ
Cone bit from the top, but a Dremel on the underside. Disc broke and the guy at Home Depot sold me the wrong replacement ones. Gonna fix it later when I brace it
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
#21 |
LMGTFY
Drives: 13 FRS, 91 Miata
As others have said, beyond trying foam and hoping of the best, its FUBAR.
Get a new trunk and megarisers. That'd be about as functional as that wing and less ricey. |
#22 | |
Famous Potatoes
Drives: '15 ultramarine
Just read this thread. Doesn't look like anyone has made it clear to OP what he did wrong, and why it is toast. What a drag (no pun intended), a new trunk and paint is a pretty expensive lesson. |
#23 |
OP, do you see where you goofed? We can discuss if you like.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Leonardo (08-15-2018) |
#24 |
By the way, this is why I would never buy a modded car.
Kid takes perfectly good trunk lid and ruins it. $500 for a new trunk $500 to get it painted. |
#25 |
$500 for a new trunk. $500 to get it painted. It adds up very quickly. |
#26 | ||
Drives: '17 PP BRZ
I'm 30, and I had just installed locking hood latches that took all my mental effort into making them flawless. I assumed this was just measure, drill, and tighten. I'm not really too worried about making a mistake on something I'd never done before. You live and learn. If the foam helps, it helps, if not, I'll buy another trunk. The one time you don't look up a DIY...
#27 | ||
| The Following User Says Thank You to Ultramaroon For This Useful Post: | texastwurkt3am (08-16-2018) |
#28 |
Famous Potatoes
Still no explanation ultra. Op still doesn't get it. The structure was there, you cut it out.
Didn't it come with instructions? |
| Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement | Ashikabi | DIY (Do-It-Yourself) Guides | 2 | 09-09-2016 05:04 PM |
| Truck brace to support a wing | 08stiguy | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-30-2016 02:52 PM |
| FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace | VoiD | Brakes, Suspension, Chassis | 2 | 03-16-2016 05:19 PM |
| sold all Whiteline Rear sway brace also dc Sports lateral brace | stiboost08 | Brakes, Suspension, Chassis | 25 | 07-19-2015 08:49 PM |
| Wobbly gas pedal? | Rayme | Issues | Warranty | Recalls / TSB | 1 | 09-30-2014 10:19 AM |
