Old 08-11-2018, 12:10 AM   #1
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
Best way to brace this super wobbly wing?
I recently got and installed the GTC-200 Drag wing from APR and as the video shows, it needs some bracing. Ideas?
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
texastwurkt3am is offline   Reply With Quote
Old 08-11-2018, 12:23 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yeah lose the wing.
Lol I'm joking.
Get larger plates on the underside mounting holes.
The Following User Says Thank You to Mr.ac For This Useful Post:
texastwurkt3am (08-13-2018)
Old 08-11-2018, 03:20 AM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
You need cinder blocks between the thin trunk alloy sheet and the chassis.
Old 08-11-2018, 11:34 AM   #4
GrantedTaken
Looks like the trunk is too flimsy to support it.
GrantedTaken is offline   Reply With Quote
Old 08-11-2018, 11:47 AM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It looks like you mounted it to the sheetmetal, and not to anything structural...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 08-11-2018, 12:15 PM   #6
gtengr
Drives: 2017 BRZ
Can you post a pic of the underside of the trunk that shows where the bolts come thru? You're going to need a custom plate on the underside that ties into the frame of the trunk lid.
gtengr is offline   Reply With Quote
Old 08-13-2018, 04:50 PM   #7
texastwurkt3am
Drives: '17 PP BRZ
Yeah... first time for everything right? Haha
Sorry, my life is a mess and I forgot I made this post https://imgur.com/a/lZ2Kqnh
Old 08-13-2018, 05:39 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'd fill the cavity where the bolts are with dense structural foam. Nice and light, and it'll stiffen the panel right up.
http://www.carbonfiberglass.com/Foam...-coverage.html
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
texastwurkt3am (08-14-2018)
Old 08-13-2018, 06:25 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
OP, If you use foam, I would highly suggest using low expansion spray foam. If you use the 3X expansion, it can warp the trunk lid. I watched my friend destroy his trunk lid by using the stuff that expands too much.
Edit: Saw the underside photo. Forget expansion foam. Either: Remove the wing and sell it. Use money to fix holes in trunk. OR Take the wing off, build underside brace plates, do body work on the damaged area - then paint, now re-install the wing. OR Get a new trunk lid and start over. Good luck!
I LIKE TIRES!
Old 08-13-2018, 06:38 PM   #10
Yoshoobaroo
TRACKBREAD
The key is to be patient and do a little at the time. If your foam expands 3X, only fill 20% of the cavity. Rinse and repeat. And don't pour foam in a large cavity through a small hole, than can cause a blockage and generate pressure.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Leonardo (08-13-2018), texastwurkt3am (08-14-2018)
Old 08-13-2018, 09:58 PM   #11
JoeC
Drives: Subaru BRZ Limited
what on earth did you use to cut those access holes?
JoeC is offline   Reply With Quote
Old 08-13-2018, 11:08 PM   #12
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
could he use that stuff from home depot great stuff or whatever its called
SuperTom is offline   Reply With Quote
Old 08-14-2018, 12:48 AM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, they sell three different expansion levels, depending on what you want.
I think longer bolts and new under mount plates are what is needed though. Forget the foam.
I LIKE TIRES!
Old 08-14-2018, 01:18 AM   #14
Brink
Drives: 2017 BRZ
Looks like a drill maybe?
Brink is offline   Reply With Quote
Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement Ashikabi DIY (Do-It-Yourself) Guides 2 09-09-2016 05:04 PM
Truck brace to support a wing 08stiguy Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2016 02:52 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 05:19 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 08:49 PM
Wobbly gas pedal? Rayme Issues | Warranty | Recalls / TSB 1 09-30-2014 10:19 AM
