Old 08-10-2018, 01:44 PM   #15
2Wavy
Drives: 2016 BRZ
I weighed my wheels and tires unmounted and added them up, and got 40.4 lbs. I think after wheel weights and tpms sensors and being filled with air, they'd probably be around 41 lbs. I have 17x9+35 RPF1s and 245/40/17 Dunlop Direzza ZII Star Specs. I could have cut a little bit more weight if I had gone with RE71Rs I think.
These wheels were around 1200 for a set of 4, and each wheel weighed 15.6 lbs. I don't think you can do much better in terms of weight unless you step up to a much more expensive forged wheel.
2Wavy is offline   Reply With Quote
Old 08-10-2018, 01:58 PM   #16
StraightOuttaCanadaEh
Wes
Originally Posted by jvincent View Post
As you stated in your post, wheels are very subjective, but for the love of God, don't get the RPF1. IMHO they are ugly.
If you want a lighter wheel, that still looks decent, check out the PF01. It's only 18.25 lbs in 18x8.5.
I agree the RPF1s do look a little dinky and the PF01 is a good looking wheel. Maybe I'll buy them as my summer wheels and keep the Raijins as my winter wheels.
Instagram: @gt86ws
Old 08-10-2018, 02:13 PM   #17
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have been looking at Forged XXR 527F 18x9 +35 wheels @ 18lb each.
IMO, Sexy and fairly light.
via Imgflip Meme Generator
They also have a 18x10 +40 @ 20.2lbs
I LIKE TIRES!
SuperTom (08-12-2018)
Old 08-10-2018, 03:30 PM   #18
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
I run 225/40/18 size wheels on my car. My rims weigh 21 lb according to Enkei and I am very tempted by the reduced weight of a wheel like RPF1 for example. Almost 5 lb, IIRC. However, wheels are highly individual and subjective, and I would still want to fill out the wheelarch. I really don't like the tiny wheel look. Having said that, I checked out tire rack for tire weights and used a Michelin Pilot Sport 4S for this comparison. I specced it in 225/40/18 and got 21 lb. Then changed it to 245/45/17 (sufficiently meaty?) and got 24 lb. That would almost negate the weight savings. Are people aware of this? Are these weights provided by tire rack correct? Cause that would take a 5 lb per corner advantage and cut it down to 2 lb...
Are you comparing a 225/18 setup to a 245/17 setup based only on weight? The reason for a wider wheel and tire is to provide more mechanical grip (all else being equal) for cornering. If you don't care about cornering and you only care about looks, then why would you care about weight in the first place? I think this one just comes down to whatever you care about the most, but if we're talking performance around a track, 17's are generally known to have the advantage.
bmxr is offline   Reply With Quote
The Following User Says Thank You to bmxr For This Useful Post:
Summerwolf (08-10-2018)
Old 08-10-2018, 04:04 PM   #19
Wes
It's a combination of surprise on my part at discovering that light 17s with a fat tire weigh almost as much as not-so-light-but-not-heavy 18s with a skinny tire, and wanting to have the same overall diameter. Cause my winters were OEM wheels with a 215 section winter tire that isn't meaty at all, so I could feel the difference in overall diameter. I want to maintain consistency and not have to get used to something new every winter/spring, so I thought with a light 17 wheel and a meaty tire I could maintain the same overall diameter. But if the weight is gonna be almost as much as an 18 anyway, there is no point. Gonna buy another set of 18s and call it a day.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
bmxr (08-13-2018)
Old 08-10-2018, 04:05 PM   #20
bfrank1972
Drives: 2013 FR-S Argento
Personally I don't care so much about wheel weights for a street car. Yeah, don't want anything that is super heavy, but used to have XXR 530's, and now have a set of XXR 527's, both cast, both 18's. Swapped stock rims and these and honestly don't notice much difference in acceleration in street driving. Ideally, get a light set of 17" x 8" rims, throw on some good track rubber 225 width and use those for track days. They can be ugly, they can be cheap, they can have road rash etc. Then get a nice set of 17" or 18" rims for the street, with wider tires and correct offsets to fill the wheel wells, don't worry too much about weight. Especially if you're adding an Edelbrock SC. my 2c
The Following User Says Thank You to bfrank1972 For This Useful Post:
StraightOuttaCanadaEh (08-10-2018)
Old 08-10-2018, 05:58 PM   #21
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Looks, to a reasonable extent. For example, I wouldn't go widebody because of the extra weight of the kit and wider wheels, but I do love the look.
As for going to 17x7-17x8 wheels, would that be sufficiently wide if I went FI, or does that depend solely on the tires?
lol no. I run a 255/35 RS4 (265 would be exactly square) on a 18x9.5 wheel and I still break traction upon acceleration if I wanted to and I'm at about 350whp.
If I were you I would get 17x9 with some stick tires, get a 255/40 for max grip. If you want a slightly stretched look get a 245/40.
17x8 is an NA autox setup imo.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
Leonardo (08-10-2018)
Old 08-10-2018, 11:25 PM   #22
Wes
Are you turbo'd or sc'd?
Instagram: @gt86ws
Old 08-12-2018, 10:57 AM   #23
Ernest72
Unless you track, stick with 17x7 wheels and 215, with a light wheel and keep the car playful.
No one will confuse your car with big wide tires with a Porsche.
If only going for looks, it’s your car do what you want, it’s all good.
I admit those meaty tire threads always look cool.
Old 08-12-2018, 03:03 PM   #24
Leonardo
Country Boy 4 Life
Leonardo's Avatar
17x7? nah, even if you stick to 215 width tires, a 17x8 will accomadate the range in width available for 215 tires better, especially if you choose utqg lower than 200. Which tend to run wider.
I LIKE TIRES!
Old 08-12-2018, 04:42 PM   #25
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Two companies that make lightweight wheels & tires at good prices:
-Look at Konig Flowformed wheels
-Tires look at Hankook Ventus Evo ii's
I wasn't sure by your post if you wanted to stay 18's or 17
245/35/18's wider and the right outside diameter at 22lbs https://www.tirerack.com/tires/tires...omCompare1=yes
245/40/17's are actually a pound heavier at 23lbs
I went with stock size 215/45/17 and got 19lbs on my scales so tirerack #'s are right
Also went with konig Hypergrams listed at 16.3lbs I got ~16.5lbs so their weights are correct as well. They don't look they great as they look small but they have a few new styles.
I like their new Dekagram wheels you can get a 17x9 at 17.3lbs
or at 18 x9.5 with concave face at 19.8lbs
https://konigwheels.com/wheels/flow-...eels/dekagram/
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Leonardo (08-12-2018)
Old 08-12-2018, 07:16 PM   #26
Wes
Thanks! Yeah when it's time to replace the MPSS, I'll pay closer attention to tire weights. I might get the Konigs as winter wheels. They're fairly priced. Don't think I'll be going down to 17s. I want to maintain the same overall diameter, which means heavier tires and it's no longer worth it.
Instagram: @gt86ws
Old 08-12-2018, 07:51 PM   #27
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I replaced MPSS with hankook evo v12. I wish I had just got another set of michelins. I do not like them. They have a soft side wall, squeel eaisly, and squirm on corners compared to MPSS.
I LIKE TIRES!
StraightOuttaCanadaEh (08-12-2018)
Old 08-12-2018, 09:06 PM   #28
SuperTom
SuperTom's Avatar
if I ever decide to go forced induction those would be at the top of my list Staggered!
Does wheel weight matter that much? smg1138 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-06-2015 04:57 AM
Wheel weight, will I notice it? Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-09-2014 03:29 AM
Wheel weight.. does it Matter? karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 08-22-2013 11:24 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 03:28 PM
What is the penalty for . . . ? calieigh Off-Topic Lounge [WARNING: NO POLITICS] 1 02-23-2010 12:54 PM
