Old 08-04-2018, 11:47 PM   #1
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Camber Bolts + Coilovers Question
I bought the whiteline camber bolts years ago and was considering throwing them in.
Looking around the forums there is a lot of conflicting info.
If I have street basis z's with stock top hats, would installing these at max camber (negative for driveability), would there be any issues beyond needing an alignment?
Thank you for all responses (in advance)
Sent from my HTC U11 life using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 08-05-2018, 05:26 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Camberbolts are just mean to get extra adjustment range at lower mount. Only negative side to these i may see, they are a bit less strong then stronger/bigger diameter OE bolts and a bit easier to slip, but that's not an issue to most, as often that heavy hits may also damage something else, and slipping possibility can be lessened via using some locktite/paint/alike.
Now if you need them .. what camber you have without rubbing if maxing out via camberplates? Is that sufficient for you? Then i'd skip installing these. If you want even more camber then with plates, install in addition to them these. Optimum camber depends on tires one use and where/how one drives. One thing is optimum camber for daily driving, another - for track.
Leonardo (08-06-2018), Strife26 (08-05-2018)
Old 08-06-2018, 06:49 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IMO, there are zero negatives to installing a set of camber bolts. The amount of camber you can achieve is not enough to cause uneven tire wear.
There are a bunch of videos on youtube. The install only takes a few minutes. TQ them down to spec and your are good.
Install them in the lower hole and move the bolt from the lower hole to the top.
I LIKE TIRES!
Strife26 (08-07-2018)
Old 08-07-2018, 01:16 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Is you top strut mount slotted? and are the Whiteline bolts you have for the top or bottom hole?
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Leonardo (08-07-2018), Strife26 (08-07-2018)
Old 08-07-2018, 01:44 PM   #5
Strife26
Strife26's Avatar
I have the top bolt option.
Old 08-07-2018, 02:07 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I am confused? Are the 16mm SPC and 16mm Whiteline parts different? If it is this whiteline product, KCA416?
https://www.rallysportdirect.com/par...ber-bolts-16mm
"On this page, you are looking at the Whiteline 16mm Camber Bolts. These bolts have been designed to provide you with more camber adjustment from the lower suspension mounting point."
The SPC camber bolts that look the same (81280), list the other mounting hole.
https://www.rallysportdirect.com/par...m-camber-bolts
"The SPC EZCam XR 16mm Camber Bolts have been designed to allow for either positive or negative camber correction of up to 1.75 degrees. These have been designed to be used with non-slotted Mcpherson struts. These are used in the upper strut to spindle bolt where the factory design uses two bolts to connect the strut to the spindle."
I LIKE TIRES!
Old 08-07-2018, 02:17 PM   #7
Strife26
Strife26's Avatar
The bolts are sold by whiteline but are engraved with spc
Old 08-07-2018, 02:27 PM   #8
finch1750
finch1750's Avatar
This has been common confusion for a long time now.
The Whiteline instructions are incorrect for the twins. The 16mm Whiteline is for the top hole on our cars. SPC 81280 is also 16mm and for the top hole. The bottom bolt is 14mm and is SPC 81305 or 81260.
There is a lot of info compiled in this thread https://www.ft86club.com/forums/showthread.php?t=103609
If the top hole is slotted there is an increased chance of slipping using an eccentric bolt. I run SPC 81260 in the bottom hole and the OEM crash bolt in the top slotted hole on both sets of coilovers I have ran with slotted upper holes without issue.
Racecomp Engineering (08-07-2018), wparsons (08-07-2018)
Old 08-07-2018, 02:38 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thank you for your detailed answer. I really appreciate it. I feel like an idiot for mixing this up!
I am using 81305 14mm EZcam in lower, and the lower OEM bolt in the upper.
I LIKE TIRES!
Old 08-07-2018, 02:39 PM   #10
finch1750
finch1750's Avatar
No problem. I'm not sure why SPC has 2 bolts that are 14mm with 2 different part numbers but there are many owners running both 81260 and 81305 and I have not seen any reported issues.
Just check them regularly as you would with any camber bolt and should be fine
Old 08-08-2018, 05:31 AM   #11
Strife26
Strife26's Avatar
My bolts are 20mm top and bottom. I guess those came with the Tein cause everything else says 14mm and 16... Maybe the Whiteline won't fit or I'm getting something wrong...
Old 08-08-2018, 12:58 PM   #12
finch1750
finch1750's Avatar
Where these new bolts that came with the coilovers? When you say 20mm is that the socket size you used? Because when we say 14mm and 16mm we are talking about the diameter of the shank and threaded portion, not the head.
Old 08-08-2018, 02:53 PM   #13
Strife26
Strife26's Avatar
Thank you. Yes I meant the bolt head. That threw me off.
FS: KW V3 coilovers with SPC control arms and Ingalls Camber bolts mkivalex Canada Classifieds 1 04-04-2016 09:19 PM
Camber bolts question AceNiNe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-14-2013 10:50 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
