Old 09-21-2017, 09:04 PM   #71
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Awesome pics!.
I have seen the kits in parts before but never all together like that lol. (Had mine installed through Coyoda)
What car did you drive with the big turbo on it Tonys? And I agree I am running the biggest turbo they offer and I do not find it laggy at all compared to the previous one I had on there with a smaller turbo and longer piping.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 09-21-2017, 11:46 PM   #72
Hags86
Drives: Toyota GTS 86
I test drove the Coyoda test mule with the FP Black turbo. I ended up buying the smaller 28xx turbo as I'm not going to build the bottom end right now. In a few years when the car is retired from daily duties I'll build the engine and put the larger turbo on then.
Hags86 is offline   Reply With Quote
Old 09-22-2017, 12:37 AM   #73
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Yup the FP black is awesome. I was lucky enough to be the test pilot for there kit with that turbo and it worked out perfectly.
You will love the kit Who is Tuning it?
Old 09-22-2017, 08:56 AM   #74
Hags86
Melbourne Performance Centre. I have a Motec M150 ECU to go with it and they are the goto guys for Motec in Melbourne.
Old 09-23-2017, 06:37 PM   #75
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
You're obviously confident and competent with the install but the distance from Melbourne, I live here as well, to either Yoda or Tony is one of the concerns I have with purchasing this kit, as brilliant as it appears to be. Quick and reasonably close support is very important, and it's a long way if you need some assistance with those little things you just know are going to pop up regardless of how sorted the kit is.
Just wondering if Melbourne Perfomance Centre are the agents for the kit in Melbourne?
Good luck with the install. Does look remarkably straight forward.
Bodalenko is offline   Reply With Quote
Old 08-05-2018, 03:50 PM   #76
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Any update on the production status of the Coyoda kit? I keep seeing a red coyoda branded 86 in Alan's Skidfactory videos, so I guess they're still testing?
Old 08-05-2018, 07:21 PM   #77
johl
johl's Avatar
Drives: toyota 86
I spoke to alan at the start of the year and he said he had 2 kits left in stock. I’m sure they would have made more once those sold. There are quite a few of these kits around where I live, but I’m pretty close to his work shop
johl is offline   Reply With Quote
The Following 2 Users Say Thank You to johl For This Useful Post:
Vin (09-22-2018), Yoshoobaroo (08-05-2018)
Old 05-13-2020, 07:47 PM   #78
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I can't find a website to check out this kit. Does anyone have a link for Coyoda?
Mike_ZN6 is offline   Reply With Quote
Old 05-19-2020, 05:02 AM   #79
johl
johl's Avatar
Drives: toyota 86
I’m not sure if it is still in production.
There is a modified kit using a Garrett g-25-660 making 400kw. It has gone through a full build and raised compression to 13.5-1 and is run by a motec ecu with massive direct injector work
Old 05-24-2020, 02:32 PM   #80
sato
sato's Avatar
Drives: Dodge Patitas
There is a modified kit using a Garrett g-30 making 400kw. It has gone through a full build and raised compression to 13.5-1 and is run by a motec ecu with massive direct injector work
Link, link!
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 05-26-2020, 04:09 AM   #81
johl
johl's Avatar
Drives: toyota 86
If you search for an australian workshop called “the 86 shop” they posted it on the 13th of May 2020. No link to a build thread but you can find the owner through the fb page of you have any questions
Old 05-30-2020, 08:35 AM   #82
sato
sato's Avatar
Found it. Thanks...again, impressive build
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 03:49 PM
JDL turbo kit thread diss7 Forced Induction 352 02-03-2019 02:04 AM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Turbo BRZ build thread IBill4You Member's Car Journals 6 03-13-2017 06:34 PM
FINDING SBD TURBO KIT THREAD myioz86 Forced Induction 2 01-21-2015 12:00 AM
