Drives: Toyota 86 GTS
Hey guys,
I recently put sound deadener in my doors for a custom stereo install, but I have since noticed my smart entry has stopped working on the passengers side. I can lock the door on the outside, but it wont unlock when I try to open the door. Drivers side works fine. Does anyone know what controls this inside the door? If someone could point it out I can maybe trace the wires to make sure they haven't been damaged. Cheers. |
#2 |
Drives: Hot Lava FRS
Pull the battery connection for a few minutes to allow the BCM to reset itself.
Otherwise - did you accidentally block some mechanical function in the door with your sound deadening? |
#3 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
| The Following User Says Thank You to KR-S For This Useful Post: | FRSBRZGT86FAN (05-28-2018) |
#4 |
#5 |
Sporadic Member
#6 |
Found the problem so deleted the post? People on the internet are weird.
#7 |
Drives: 2018 BRZ
I'm having the same problem only on the driver's side. Opened up the door for sound deadening install as part of a speaker upgrade last week, but I'm not sure it's related since it was working for a few days after. Passenger side keyless works, and driver's side keyless lock works, but the unlock doesn't respond.
Anyone ever find a solution aside from resetting the BCM by disconnecting the battery? Not seeing anything in search. -Boog |
| Tags |
| door, smart entry, wiring |
| Do we really have keyless entry? | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 10-22-2013 11:04 PM |
| Torque Pro Working on Parrot Asteroid Smart | Brandon__ | AFRICA | 7 | 06-21-2013 12:21 PM |
| Keyless Entry Delay/Not Working | Dezoris | Issues | Warranty | Recalls / TSB | 0 | 11-02-2012 07:57 PM |
| Aftermarket Push Button Ignition Smart Entry System | zAnSh1n | Electronics | Audio | NAV | Infotainment | 75 | 08-19-2012 03:23 PM |
| BRZ Keyless entry? | Motopythons | CANADA | 7 | 06-03-2012 06:56 PM |
