Old 07-14-2018, 06:20 PM   #1
Ashikabi
Ashikabi's Avatar
Quick fuel line question
Can someone educate me on what each of these fuel lines is for? I assume one is port injectors, direct injectors, and the last is evap? Which is which?
Old 07-14-2018, 07:52 PM   #2
twag4
Drives: frs
Top is port, middle DI, and bottom is evap
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
CSG Mike (02-06-2020)
Old 07-14-2018, 09:13 PM   #3
Ashikabi
Ashikabi's Avatar
Thank you sir
Old 07-14-2018, 09:18 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
From the picture, your car seems to be missing something, but I can't quite put my finger on it...
Windshield wipers maybe?
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (07-14-2018)
Old 07-14-2018, 10:01 PM   #5
Ashikabi
Ashikabi's Avatar
Yeah, just the blades though
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Spuds (07-14-2018), Ultramaroon (07-15-2018)
Old 07-14-2018, 10:09 PM   #6
Ashikabi
Ashikabi's Avatar
Say, since you replied first... Do the 2 injector lines get equal feed from the pump? I have to hook it up to a V8
Old 07-15-2018, 01:00 AM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Bottom is the one that gets used when you install a FF kit, correct?
Originally Posted by humfrz
I'm old and lazy
Old 07-15-2018, 11:43 AM   #8
twag4
Drives: frs
I’m not sure of that
Old 02-06-2020, 04:54 PM   #9
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Just since I was also searching for that information: The given assignment in Post #2 is incorrect. (Or I missunderstand the description) I know its late, but maybe important for other U's rwading this thread. Here is what the inspection manual says: (see chapter "port injector removal")
The top line in this picture (which is the most rear in the tripple plastic clamp) is fuel line #1, used for port injection.
The middel line (which is also the middle line in the tripple plastic clamp) is fuel line #2 which is the vapor/evap line.
The lower line (which is most to the Front in the tripple plastic clamp) is fuel line #3 used for DI.
Concerning the last question: #1 & #3 are both leading to the intank pump and gauge assembly. One line is coming from the pump and shortly after that it splits into two lines. Just T'ed. No valves or anything. So pretty much the same. Dont know the reason why they did it like that, maybe there is a Kind of Bad pulsation when DI and port are both working. But I'm not complaining, for a LS swap its perfect, no need to change for larger diameter fuel line.
@swappers: Be careful, not a good idea to missmatch those lines. You will float your charcoal canister through the EVAP vent line since its connected to the intank fuel pump if you T together lines #1&2. No fun to exchange that, since you need to remove the diff carrier assy to get to the evap canister.
Good thing is that you should not be able to run the (LS) engine if you did it like that. This beeing said, if somehow it should run (what I dont expect, but I wont try out) you will float your intake with fuel the second the Purge valve opens. Best case then would be a bent connecting rod, worst case is you have a expensive BBQ.
TRS is offline   Reply With Quote
Old 09-17-2021, 01:43 AM   #10
Fatboy412
Fatboy412's Avatar
Drives: 2013 FRS
so if i use line #1 wht do i do with line #3 ?
Fatboy412 is offline   Reply With Quote
Old 09-17-2021, 07:56 AM   #11
Ashikabi
Ashikabi's Avatar
I Teed mine back together. You can probably just use one and cap the other though
Sent from my ONEPLUS A5010 using Tapatalk
Quick shifting technique that minimizes drive-line lash? brillo Engine, Exhaust, Transmission 14 07-14-2017 05:19 PM
WTB OEM Fuel Line #maverick# Want-To-Buy Requests 0 06-03-2015 03:33 AM
Direct injection quick connect fuel line part number? post_break Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2014 09:12 PM
Magnets on the fuel line for better performance/economy? mike the snake Engine, Exhaust, Transmission 31 12-28-2013 07:46 PM
Quick question about fuel firl21 Engine, Exhaust, Transmission 8 06-03-2013 10:13 PM
