Old 06-01-2013, 06:13 AM   #1
firl21
Drives: Scion FRS in hot lava
Quick question about fuel
I found an E-85 station close to my house and since its 70c cheaper per gallon than premium I was wondering if it would be a suitable replacement. Now I have not put it in my car yet, but I do know that E-85 is used in all the performance dynamos and I assume its the same thing. My car is still Bone stock Minus tools and tire. Can I use e-85 without any long term or imidiate dammage to my engine. Also Will it increase performance in anyway, If it does or decreases performance i would like to know how so and by how much.
Thanks
TLDR
Will E-85 from the pump be fine for my car, and will it increase performance
firl21 is offline   Reply With Quote
Old 06-01-2013, 08:52 AM   #2
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
The manual specifically says not to use e85. You have to have a special aftermarket tune to use it, and some people using it are now posting threads with fuel pump problems and fuel filters falling apart.
TL;DR - don't do it.
Freetime is offline   Reply With Quote
Old 06-01-2013, 09:44 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Freetime View Post
The manual specifically says not to use e85. You have to have a special aftermarket tune to use it, and one person using it are now posting thread with fuel pump problem and fuel filter falling apart.
fixed your post.
there is one documented case that I'm aware of with a user's fuel filter that may (or may not) be related to their usage of E85.
Not multiple failures.
Not multiple people.
Not multiple filters.
One.
I'm not saying it's safe, or encouraging anyone to go fill up with E85 right now. But at the same time let's keep this in perspective here and not start exaggerating. At this point in time, it's a single isolated incident.
The Following User Says Thank You to xjohnx For This Useful Post:
Opposed (06-03-2013)
Old 06-01-2013, 09:55 AM   #4
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
If the owner's manual says not to use it, that's enough for me.
jeffchap is offline   Reply With Quote
Old 06-01-2013, 10:09 AM   #5
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
You can use e85 with a tune designed for e85. You do have to weigh the performance versus MPG aspect, not sure if MPG is any importance to you. Your gas mileage will drop by probably 25%.
UnOvertime is offline   Reply With Quote
Old 06-01-2013, 10:10 AM   #6
jamesm
Don't do it. You may or may not regret it a couple years from now. The benefits don't outweigh the risks at this point. Anyone who tells you 'don't worry, it's safe' has no basis upon which to assert such a thing.
Old 06-01-2013, 11:09 AM   #7
FR-S Matt
e85 hasn't been tested long enough to see the longterm effects on this car. I'd personally hold off and let others ruin their fuel lines and engines first if they've got more money to spend on replacements.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Fast_Freddy (06-04-2013)
Old 06-03-2013, 11:06 AM   #8
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
If you are only interested in e85 since it is cheaper per gallon then I'd say don't bother. E85 is cheaper, yes, but requires more fuel per amount of air to make the same power. Aka your mileage drops 20-30% and there is no cost savings then
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-03-2013, 09:13 PM   #9
wparsons
wparsons's Avatar
Regardless of longterm longevity, you NEED a proper e85 tune (or flex fuel kit). If you just put e85 in on the stock map it'll run way too lean.
flickr
New guy with a quick question Bullnettles Engine, Exhaust, Transmission 28 05-09-2013 12:03 AM
Quick Question geb2391 BRZ First-Gen (2012+) — General Topics 2 04-07-2013 11:41 PM
Quick Question akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-04-2013 09:29 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 11:02 AM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 09:53 PM
