Old 06-09-2018, 12:16 AM   #645
Lantanafrs2
Drives: 2013 frs red
I would get your debit card, put at least another 5 gallons in and drive it. Give it 20 miles or so, then look at your real time diagnostics.
Lantanafrs2 is offline   Reply With Quote
Old 06-16-2018, 07:45 AM   #646
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
LT Fuel trims are still negative. I've driven 125 miles or so on E85 now.
25 miles or so - https://datazap.me/u/narfalicious/e851?log=0&data=1
more than 125 miles - https://datazap.me/u/narfalicious/e8502?log=0&data=1
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 06-16-2018, 10:16 AM   #647
steve99
Drives: FT86
fuel trims loog a little negative but that's normal on first tank of E85 due residual petrol
the logging of some parrameters is incorrect, assume your on older v2 tune.
if you use V4 tune then logging will be correct
Old 06-17-2018, 10:29 PM   #648
Eff
Drives: Toyota 86
is there anyway to see if the oil in my car is suited to run E85? i've done alot of research trying to find information on the oil that was put into my car when it got serviced recently (Valvoline Synpower 0W20) its not really mentioned anywhere on the internet and it mentions E85 once on the PI sheet but im not sure its really suited
Thanks in advance
Eff is offline   Reply With Quote
Old 06-17-2018, 10:54 PM   #649
steve99
Drives: FT86
Thanks in advance
If its rated SN or GF5 it will be E85 compatable
Old 07-11-2018, 04:32 AM   #650
airrick
Drives: TRD R.S. 1.0 FRS
hi,
so this is my first tank of e85. my afr seems pretty high. especially when im just in gear cruising without any throttle is shows 20 for the afr. should i be worried?
https://datazap.me/u/bboyairrick/3rd...-12&mark=10647
airrick is offline   Reply With Quote
Old 07-11-2018, 07:58 AM   #651
steve99
Drives: FT86
Originally Posted by airrick View Post
hi,
Yes thats normal during overun with zero throttle injectprs are turned off so afr goes to max lean reading of sensor in this case 20
See ECU logging link below
Old 07-20-2018, 03:58 PM   #652
BOND007_LTK
Drives: 2013 brz
Mixing
I've got just openflash tablet on stock car and wanna try e85. No flex fuel.
I've found a shop in canada that sells e100. To get e85 can I just fill up with e100 and then 93 pump gas on my car? Appropriate volume of course.
Does it mix on it's own or do I have to mix it externally out of the car?
BOND007_LTK is offline   Reply With Quote
Old 07-20-2018, 05:48 PM   #653
steve99
Drives: FT86
should work id probably mix it to about E70-e80 if on a standard oft tune as that's about the middle of the operating range
Old 07-23-2018, 04:14 AM   #654
airrick
This was during a 2nd gear pull.
Everything look normal? It seems like im running a little rich. what AFR do i want to be at during WOT?
https://datazap.me/u/bboyairrick/sup...5-650&mark=277
Old 07-23-2018, 04:25 AM   #655
steve99
Drives: FT86
Afr and commanded afr should be closecinder full throttle yes you are running about 8% richer than commanded afr. Lkely needs some maf scaling
Old 07-23-2018, 06:50 AM   #656
airrick
im pretty new to this tuning thing, but from what I read in your OFT threads, steve. That MAF scaling is driving around at low rpm and steady throttle correct?
what im trying to do is let my ecu learn the trims better correct?
Old 07-23-2018, 07:10 AM   #657
steve99
Drives: FT86
No maf scaling requires collection of data and then recalibraringvthe mas aor flow sensor tables in tune to correct the fueling error
airrick (07-23-2018)
Old 07-23-2018, 03:17 PM   #658
airrick
Hmm. Im too much of a noob for now to touch the OTS tune table in rom raider without ruining the whole tune.
Thanks though steve.
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
