Drives: 2013 FRS
Whiteline swaybar setup
I have recently fitted my FRS with a 20mm non adjustable whiteline front swaybar, as well as an 18mm adjustable whiteline rear swaybar.
I'm wondering what setup I should run on the rear bar to compliment the 20mm front. I'd like to keep the handling neutral and similar to stock if possible. I currently have it on the middle setting in the rear, but haven't hit the track yet. |
#2 |
Drives: '13 FRS - STX
Test, then adjust, it will be preference.
Influenced by alignment, suspension, tires, and driving style. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Spuds (07-08-2018) |
#3 |
Closest to stock would be rear bar on the softest setting. Adding the 18mm bar in general will probably pushyour car towards oversteer when you lose grip.
| Whiteline Greaseless swaybar bushings.. | BRZHarley | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-28-2017 11:44 AM |
| Whiteline spring and swaybar kit | Purist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-11-2017 07:54 PM |
| FS: Whiteline 16mm Rear Swaybar | smg1138 | Brakes, Suspension, Chassis | 0 | 04-30-2017 06:37 PM |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 12:00 PM |
| FS: Whiteline Front Swaybar Endlinks | bombardius | Brakes, Suspension, Chassis | 2 | 04-16-2016 10:50 AM |
