-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Whiteline swaybar setup (https://www.ft86club.com/forums/showthread.php?t=128819)
mhiscott 07-08-2018 12:48 AM
I have recently fitted my FRS with a 20mm non adjustable whiteline front swaybar, as well as an 18mm adjustable whiteline rear swaybar.
I'm wondering what setup I should run on the rear bar to compliment the 20mm front.
I'd like to keep the handling neutral and similar to stock if possible.
I currently have it on the middle setting in the rear, but haven't hit the track yet.
strat61caster 07-08-2018 11:10 AM
Test, then adjust, it will be preference.
Influenced by alignment, suspension, tires, and driving style.
norcalpb 07-08-2018 03:52 PM
Closest to stock would be rear bar on the softest setting. Adding the 18mm bar in general will probably pushyour car towards oversteer when you lose grip.
