Drives: Silver
Car Won’t Start SBD Kit W/Tune
The car has been parked for at least 4 months with the battery taken out because a pulley warped and I didn’t feel like working on it right away. I changed the fuel injectors and fuel pump (700cc injector 300 DW Pump ) got no start so I put the stock pump and injectors back on and the car still wouldn’t start. Any ideas ?
#2 |
Rust bucket enthusiast
Did you at least try jumping the battery? When you say it won't start, does it crank? Does it do nothing? Did you replace the warped pulley? Could be a crank position sensor or cam position sensor If you didn't get a tune for the injectors, there's a good chance it's not going to start easily/at all.
#3 |
Drives: Silver
It cranks comes on for a brief second then shuts right back off
#4 |
Drives: Silver
UPDATE: Talk to a buddy he believes I’m not getting any fuel to the injectors
#5 | |
Drives: Silver
#6 |
Are you sure the battery is good?
humfrz |
#7 |
Have you happened to mess with the DI ecu? If it's not attached or the bolts aren't properly tightened it wont get it's ground and therefore cause a no start condition
#8 |
Drives: Silver
Yea I moved the ECU back a little to have more space to work. I will try tightening it back up and see if that helps.
#10 |
Drives: Silver
Sorry for the late replies being the army and working on my car is a struggle sometimes.
| The Following User Says Thank You to ImRealUgly For This Useful Post: | humfrz (07-03-2018) |
#11 |
#12 | |
Make sure its bolts are tightly and properly attached to that injector crash rail and its mount the way it was on the OEM has it (minus the sound tube stuff): ![]() I circled it in red for ya
#13 |
Drives: Silver
#14 |
Drives: Silver
| B01D 6AT SBD Turbo Tune Questions *Tune Attached* | Pro60modman | Software Tuning | 6 | 09-05-2016 09:04 PM |
| Cold start issue(tune or injectors?) | 86 driver | Software Tuning | 0 | 08-01-2015 02:49 AM |
| car wont start after tune | JesseTheFlash | Software Tuning | 7 | 12-17-2014 12:43 PM |
| Rough start but no tune.... | _F-R-S_ | Issues | Warranty | Recalls / TSB | 27 | 02-26-2013 10:07 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
