Old 07-05-2018, 10:42 AM   #15
freerunner
freerunner's Avatar
Drives: GT86
Should 'feel' the same. Unless you get FLKC. Or if your port injector scaling is off.
Originally Posted by tomm.brz View Post
Yes of course in my tunes i keep PI 9-10% from 5200 and more ignition timing
I like it more than >20% PI feels more awake
freerunner is offline   Reply With Quote
Old 07-05-2018, 11:22 AM   #16
tomm.brz
Drives: brz 2017 hksv2
Yes well. It pulls good like a good tune with more PI
I scaled PI injection reducing it from 228 to 220 because with 228 it leaned a lot against DI and i raised a lot the ign timings to run just 10% PI
Old 07-05-2018, 12:23 PM   #17
ITmushishi
ITmushishi's Avatar
Drives: 2016 FR-S
Thanks for sharing your experience @Tor. I did not know any of the tuning solutions that work with the stock ECU hardware could do anything about per gear timing. Interesting! (Currently I'm still tinkering with RomRaider and some of my own tools for data log crunching.)
Good catch @tomm.brz, easy to keep that table correct.
ITmushishi is offline   Reply With Quote
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 01:21 AM
Final Drive Swap Break-in azynneo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 12-04-2015 03:11 PM
Ecu Tuning after Final Drive Swap Toyota86.ir Software Tuning 14 11-17-2015 03:39 PM
final gear swap on AT xsnapshot Engine, Exhaust, Transmission 2 02-19-2015 08:25 PM
My final gear swap project PantsDants Engine, Exhaust, Transmission 120 06-29-2014 08:24 PM
