Old 07-02-2018, 06:33 PM   #1
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
help - voltage oscillates
I flashed back from V4 back to V3 yesterday and noticed today that my voltage is oscillating form 12v to 14v - up and down and wont hold steady at 14V. is this normal? Even if I rev it it doesn't jump to 14v, it just continues to oscillate back and forth.
thoughts?
Last Lemming Alive is offline   Reply With Quote
Old 07-02-2018, 07:03 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Are you saying that it continuously oscillates? If so, that doesn’t sound normal. The voltage does fluctuate between 12-14 volts at different times though... but not a constant fluctuation.
NCtoBRZ is offline   Reply With Quote
Old 07-02-2018, 07:13 PM   #3
Last Lemming Alive
If I start the car and let it idle it stays around 14v, however, if I rev the car the voltage will drop to 12V and hold for a while. The AC is on as well btw and its 100 degrees outside.
Old 07-02-2018, 07:23 PM   #4
Do you have a MIL?
Old 07-02-2018, 07:42 PM   #5
Last Lemming Alive
Do you have a MIL?
there is no warning light that comes on.
I just took it on another drive. I noticed that if I rev the car the volts drop to 12V. If I come to a stop the volts go back up to 14V. I checked the voltage at the battery with a multimeter and it follows what's on the dash gage.
Old 07-02-2018, 08:09 PM   #6
Sounds like it's fine but the service manuals are in my sig line if you want to verify.
Old 07-02-2018, 09:05 PM   #7
Last Lemming Alive
I would have thought that revving the engine would have caused the voltage to peak not drop.
Old 07-02-2018, 09:20 PM   #8
Guess not.
Old 07-02-2018, 09:31 PM   #9
Last Lemming Alive
I tried looking at the service manual however it’s not very clear what is normal and not normal. It talks about what the battery voltage should be but not necessarily what the correct charging amps and voltage should be at any specific rpm Or how to test it without having hook up a computer to it For diagnosis.
Old 07-02-2018, 09:57 PM   #10
Semiihcircle
Drives: 17 BRZ
My BRZ does that too, im not too sure why. i cant even tell you when it happens, there is no set of particular conditions that occur when my voltage oscillates. but is not a constantly going from 12 to 14v and back to 12V. sometimes its just hanging out at 12V then jumps to 14V for a little while. there is no noticeable difference in ride.
I just accept it as is, at this point. im also completely stock for now!
Semiihcircle is offline   Reply With Quote
Old 07-02-2018, 10:41 PM   #11
Last Lemming Alive
And how long has it been this way
Old 07-03-2018, 08:35 AM   #12
Grady
Grady's Avatar
Mine is a new 2017, been that way since new. It appears to be programmed into the charge logic. Keep from overcharging the battery, reduce load on engine, or something?
Old 07-03-2018, 09:15 AM   #13
Last Lemming Alive
I have a 2017 too, but mine just started doing this after a year of ownership
Also I noticed mine drops all the way down to 12.0V unless I’m decelerating. Only under deceleration does it go up to 14V
Old 07-03-2018, 10:48 AM   #14
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
Perfectly normal for the 2017+.
Turn on the headlights, it will stay at a steady high voltage.
PhyrraM is offline   Reply With Quote
O2S2 Voltage Always Zero bhaugen2 Engine, Exhaust, Transmission 22 09-14-2022 05:35 AM
What battery ecu voltage are you getting with torque pcguru2000 Issues | Warranty | Recalls / TSB 8 05-08-2018 08:53 PM
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 08:15 PM
Voltage fluctuations Andrew666 AUSTRALIA 7 03-19-2013 09:44 AM
