Drives: 2014 Scion FRS Track Build
Hey guys,
So I was replacing my wheel studs and removed the front two wheel bearings in the process. As this was my first time, I accidentally forgot to remove the ABS/speed sensor on the first bearing. I didn't pull hard and soon realized the bearing was stuck due to the sensor not being removed. Upon inspection the sensor appeared fine but it may be fragile and the damage may not be visible. Anyway, after driving the car for about 5 minutes, the Traction and ABS lights came on. I scanned the car with my Open Flash and got P0462 which had to do with low fuel (I had half of a tank?). I erased the code and the traction and ABS lights are still on. No limp mode or CEL. I fear it may be due to the ABS sensor being possibly damaged but I'm not sure. The Open Flash still reads no codes but it does not read body codes so it could be the ABS Sensor. I have an old OBD2 code reader so I used that but still no code Here's my question: Do you think a newer code reader would find the issue that an old code reader would not find? If so, which do you recommend Also, any advice for diagnosing the issue without taking it to a dealership or shop that would charge me to diagnose it? Thanks |
#2 | |
The dealership will not only charge to diagnose they'll charge because it's been "tampered with" You'll need to find a code reader with ABS and SRS capability, I think some bluetooth OBD Elm327 ones have that capability
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | neroman98 (07-02-2018) |
#3 | |
… that's fer not payen attention to what you were doin … replacing the wheel studs is a 2 beer job, not a 4 beer job!Now that you messed up the sensor and you know how it comes off and goes on, I suggest you buy a new sensor and put it on. Then take er fer a spin and report back. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sportsguy83 (07-23-2018) |
#4 | |
#5 | |
However, since your car was working OK before you ripped out the ABS/speed sensor, then when you put it back together, you get traction and ABS lights on the dash.. I would think that would be diagnosis enough … ![]() How does the old saying go - paralysis by analysis .. ![]() DAMN it's a slow day in Puyallup … ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | neroman98 (07-02-2018) |
#6 |
I'm with humfrz here, it's highly unlikely its anything else. It's definitely tied to your wheel stud install
#7 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Agree with the others. The odds are VERY high that it's an issue with that sensor. Having said that, a proper code reader is a fantastic tool to own as well...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | neroman98 (07-02-2018) |
#8 |
I will buy a code reader, diagnose the issue and get back to you guys on what happens. Definitely annoyed that my small mistake may have cost $100 for a new sensor but that’s the name of the game...
| The Following User Says Thank You to neroman98 For This Useful Post: | humfrz (07-02-2018) |
#9 |
A.K.A. Starlord
Shit happens. Wait until the car gets older. Rusty bolts, brittle hoses and plastic unions, etc... you end up breaking stuff that costs twice as much, and takes three times longer to repair than the part you were originally trying to fix.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 07-02-2018 at 05:18 PM. |
| The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | FRSBRZGT86FAN (07-02-2018), humfrz (07-02-2018) |
#10 |
I'd suggest innova line of products, I've gotten tired of OBD2 bluetooth stuff for diagnostics honestly
#11 |
Disconnect the negative battery terminal for 30 min reconnect and see what happens.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
Just a final update for anyone interested- I bought this OBD2 scanner: https://www.amazon.com/Veepeak-OBDCh.../dp/B073XKQQQW the scanner works great, and after testing a couple apps I found one that detected ABS and SRS codes. Most apps do not detect these codes but Carista for IOS did. To my dismay, it cost $10 for the app to actually list the codes so that I could diagnose the car, but I could not find any free app that would diagnose ABS codes. It was the front RH speed sensor (Shocker). Hope this helps anyone in a similar situation!
| The Following 2 Users Say Thank You to neroman98 For This Useful Post: | humfrz (07-09-2018), Sportsguy83 (07-23-2018) |
#13 |
Drives: Sideways
Changing the sensor made the warning light disappear ? Or you had to clear the code with the app ?
Do you know if that app can reset the steering angle sensor ? Thank you. |
| Tags |
| abs and traction lights, abs sensor, cel, code reader |
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 10:00 PM |
| Abs and traction light no tailights replaced brake light switch now what? | Brzlimited661 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-28-2018 07:04 PM |
| traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 10:28 AM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 08:37 AM |
| CEL ABS and Traction Light | DieselxIndustry | Issues | Warranty | Recalls / TSB | 3 | 01-31-2013 02:04 PM |
