Old 06-26-2018, 01:25 AM   #15
15limited
15limited's Avatar
I bent the " inductor ring" I believe it was called, which is what the wheel speed sensor monitors. I dont think you'll have any problems driving in limp mode, I never read anything about sporadic braking fits or unpredictable driveability, iirc the abs system either works or it doesnt, which should be why the lights come on shortly after startup and stay on until they're cleared or restart the car.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 07-01-2018, 09:18 AM   #16
kuyumoy
Drives: scion frs
Originally Posted by Stang70Fastback View Post
Sure. Nothing will explode. Your ABS, and other driver aids will not be functional, so keep that in mind. Drive cautiously until you have it fixed.
You might consider pulling one of the ABS fuses in the meantime to fully disable it. I've seen weird stuff happen as a result of damaged sensors (ABS coming on when it wasn't supposed to, which significantly increased stopping distance, for example.)
thanks, finally got the replacement abs sensor and installed it. lights are gone. AWESOME 😀 appreciate your help bro
kuyumoy is offline   Reply With Quote
Old 07-01-2018, 09:21 AM   #17
kuyumoy
Drives: scion frs
[quote=humfrz;3102977]
Originally Posted by kuyumoy View Post
Well, I would suggest that you NOT drive the car until the brakes are fixed. If it's absolutely necessary to drive the car, drive very carefully and get familiar with using your emergency brake ..
Back in the day, when we had only a single cylinder braking system and we pushed the brake pedal to the floor .. and it just stayed there, we learned how to rev match/downshift and pull on the emergency brake … all at the same time, as you looked for a soft spot in the ditch.
(that outta convince you to keep er off the road)
lol im not good on using the emergency brake haha but luckily the abs replacement arrive early and got a chance to installed it right away and lights are GONE. thank God haha thanks for the help man appreciate that 👍🏼
The Following User Says Thank You to kuyumoy For This Useful Post:
humfrz (07-01-2018)
Old 07-01-2018, 09:24 AM   #18
kuyumoy
Drives: scion frs
Originally Posted by highway7 View Post
Normal for traction light to come on, I can explain in detail but basically the traction system is "ABS" while driving. Ex, if your car detects slip it will brake certain wheel(s) to maintain control with traction control on.
Not sure why CEL is on buy most likely related.
Replace wheel speed sensor and car should be fine to go right away.
most thread that I saw said that the CEL might be on when you got more than 1 light on in the dash so I guess that will be the reason why the CEL is lights on as well lol but thankfully I got to fix it right away 👍🏼 hehe thanks for the input, apprecciate it
Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? Anthonyc77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-19-2018 09:57 PM
So i broke my wheel speed sensor bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2016 05:04 PM
Broke Oxygen Sensor during Header Replacement - Can i run w/o one? Adeel Engine, Exhaust, Transmission 7 05-20-2014 03:12 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
