Old 06-23-2018, 08:12 PM   #1
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
2015 FRS Keyless Entry Not Functioning
Hello,
Thanks in advance for any help. I spent an hour searching and haven't found a solution to my problem.
The buttons to unlock the doors and trunk on my key fob no longer work on my FRS. I also tried my spare key fob which has never been used, same problem.
I opened the car door manually with the physical key and the car starts up and runs just fine. No hesitation.
3 year warranty ran out a few days ago...
Anyone had a similar issue and know the solution?
Only mod that could be related is the OFT, which was tuned about two months ago and car has been fine since then.
Thanks!
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 06-23-2018, 08:20 PM   #2
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
May be a silly question, but have you tried changing the battery? Might be it's just ran out of juice, and the spare key could run into the same problem even if it's just been sitting for a few years/
Geese1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Geese1 For This Useful Post:
humfrz (06-23-2018), SkiRideDrive (06-25-2018)
Old 06-23-2018, 08:22 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
True, the spare key drains just as quickly, the keys continuously transmit.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Old 06-23-2018, 11:30 PM   #4
I'm ah feared you're gonna be embarrassed (but, you will be happy) when you put new batteries in your fobs.
Old 06-24-2018, 03:05 AM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by SkiRideDrive View Post
Hello,
Thanks!
OFT doesn't mess with the BCM/BCU so it wouldn't effect the keys.
Make sure you replaced the batteries in the key fob first.
Otherwise you'll need to get techstream and/or go to a dealer and see whether they can diagnose why its not acting on a signal it receives but the transponder works find and disables the immobilizer to start the car.
Old 06-25-2018, 01:16 PM   #6
SkiRideDrive
Drives: 2015 FRS
Well thanks for the suggestion guys. You were right. Replacing the batteries in the key fobs was the answer. I really thought the key which was never used would have outlasted the one used daily but I was wrong.
Easy fix, a good day.
The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post:
02.ACCORD.DUDE (06-25-2018), Geese1 (06-25-2018)
Old 07-04-2018, 09:09 PM   #7
dnieves
Drives: FR-S 10 Series
Usually the first sign something is amiss with the fobs' battery is the gradual reduction in distance to lock/unlock the doors. Once you need to be within a few feet I change the batteries on both.
dnieves is offline   Reply With Quote
Keyless Entry not working! Frs x3 Scion FR-S / Toyota 86 GT86 General Forum 16 10-20-2015 04:10 PM
keyless entry not working ninjasaurusrex Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2014 09:08 AM
Keyless Entry Upgrade Tr1huynh Electronics | Audio | NAV | Infotainment 3 02-24-2014 08:07 PM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 10:04 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 05:56 PM
