| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3809 | |
Drives: 2019 Toyota 86
And it would be my daily driver. |
#3810 |
Drives: 2014 GT86
I don't intend to go FI so haven't gathered info/not familiar with this turbo kit aswell, but possibly with FI & tracking i'd go for a bit wider. Of course square wider tires, not staggered wider in rear only.
#3811 |
#3812 |
Drives: 2014 GT86
That's a bit subjective thing and of tires chosen. Some track slicks or cheater tires like RE71 may grip well even in lower widths, less track specialised tires like PSS/AD08 maybe wider. Also depends on wheel width you have, as there are optimum tire widths per wheel widths. On stock wheels something too wide will have too much sidewall flex.
Also remember, as sidwall profile is in % of width, unlike for 225/45 which is not that far from stock, 235 and up with same 45% sidewall will be of noticeably larger diameter, so worth dropping down a notch, eg. for 235-245-255 i'd go for /40, for 255-265 - for /35 |
| The Following User Says Thank You to churchx For This Useful Post: | Ryan GT86 (06-13-2018) |
#3813 | |
Rim offset is 45 mm. Last edited by Ryan GT86; 06-13-2018 at 06:32 AM. |
#3814 |
Drives: 2014 GT86
I see no reason for such sized tires or wheels to have clearance issues. x8 should be ok for 215-245 tires, x9 for 235-265. Those that go for very meaty looks or for widest wheels they can fit often have wider/bigger setups then that.
#3815 | |
Country Boy 4 Life
A 17x9 +45 is not going to work on a stock car. You will need a slightly lower offset, a spacer, or coilovers. You will either be 1mm from the spring perch or touching it. +35 17x9 will work with springs. And will give enough room to add camber bolts. A 17x8 +45 will not rub at all, even with a 245/40/17. I have had these sizes with the same size tires at stock height and lowered 1". (with and without camber bolts too)
I LIKE TIRES! |
#3816 | |
| The Following User Says Thank You to Ryan GT86 For This Useful Post: | Leonardo (06-14-2018) |
#3817 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Have staggered PTR56-18130 PTR56-18131 TRD wheels. 7.5 inc rear and 7 inch front width. Got em as a killer deal brand spanking new at dealership for $749.99.
Can I run square 215 40R18 even-though rear is .5 inch more? Any foreseeable problems?
| The Following User Says Thank You to Packofcrows For This Useful Post: | Leonardo (06-19-2018) |
#3818 | |
Country Boy 4 Life
Yes. Square 215/40 will fit no problems on 18x7 & 18x7.5. Though TRD suggests 215/40 front and 225/40 rear. But, I don't see any real advantage to the mini stagger; other than looks. The stretch will look even with the mini stagger. Cool wheels! Great deal! Please post pics when you get them installed!!!
I LIKE TIRES! |
#3819 |
Thanks, next 2 weeks ill swap em out from stock wheels to those 215 40 18's then.
| The Following User Says Thank You to Packofcrows For This Useful Post: | chaoskaze (06-22-2018) |
#3820 |
Drives: 2017 Toyota 86
Hey guys, I actually went ahead and ordered 4x 18x8.5 +38 Work Emotion Kiwami Wheels. Would 225/40/18 tires stretch on a wheel this wide and are there any safety risks with stretching a tire?
I was also thinking about going 235/40/18 all around but wasn’t sure if it would rub on TRD springs at full lock (like doing a U-turn). Sent from my iPhone using Tapatalk |
#3821 | |
Drives: 2015 Firestorm FRS
I have 17x9+38 with 245/40/17 using trd springs
No rubbing Quote:
| The Following User Says Thank You to carlovestela For This Useful Post: | HachiRokuX (06-23-2018) |
#3822 |
Drives: 2013 pearl white FR-S
| The Following User Says Thank You to DarkSideFRS For This Useful Post: | HachiRokuX (06-23-2018) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
