#85 | |
Drives: 2013 Hot Lava FR-S
Sent from my SM-G950U using Tapatalk |
#86 |
Hey, I've got a set of Winjet headlights in my FRS. I'm thinking about doing halos, but have no idea on what size of halos to even look at for those headlights. Any idea without tearing them apart and measuring?
#87 |
My oem driver side BRZ headlight has been flickering a ton lately. What exactly could be causing this? Could it be a bad relay?
#88 |
Drives: 2013 WRB BRZ Limited
#89 | |
-B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | norcalpb (05-31-2018) |
#90 |
#91 | |
it looks like you can use 1 of 3 sizes depending on how large you want the halo to appear or fit. -B |
#92 |
Forgot to mention I swapped bulbs and the other side started flickering, so I replaced bulbs and problem solved thanks so much man!
#93 |
#94 | |
#95 |
Drives: 2014 Scion FR-S Monogram
Hi there,
I'm new to the forum, sorry if this might be asked before. I have a 2014 Scion FR-S Monogram series. When I purchased the car it came with OEM foglights and recently my driver side foglight got busted and was wondering which aftermarket foglight is closest to OEM quality? Found out that one OEM foglight from Toyota costs around $300, not sure if I want to spend that much.. Also I plan on switching out the bulbs to match my OEM HID headlamps, any suggestions on which bulbs to use without melting the foglight housing? |
#96 | |
Otherwards ebay has a ton of used ones cheap. The brz and FRS use the same fog light housing so feel free to search for either. If interested in either let me know, I can get you special pricing through them! -B TRS - Morimoto https://www.theretrofitsource.com/sc...to-xb-led.html Baja Designs https://www.bajadesigns.com/products...Light-Pair.asp Brackets https://www.paranoidfabrications.com...gn-fog-bracket |
#97 |
Thanks for the advice.
I'm thinking of going for the Morimoto foglights from ft86speedfactory. http://www.ft86speedfactory.com/mori...l#.WynFzKczphE |
#98 |
Drives: TRD R.S. 1.0 FRS
Okay. So i have a rs 1.0. They dont have fog lights. I bought the winjet fog lights for the monogram/release 10 series. Because i wanted to have the oem factory cover with switch on it. All it comes with is everything except oem cover thing. If i buy one of them from 86speed.com will it fit my rs frs?
https://www.86speed.com/new-products...witch-kit-frs/ I would have gotten the normal one but where normally frs have an unused button next to the trunk lock button, the rs 1.0 uses the unused slot for moving up the headlights This is such a pain for fog lights. Last edited by airrick; 07-03-2018 at 08:37 PM. Reason: More info |
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 03:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 08:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 01:19 AM |
