#15 |
Drives: 2013 FR-S, 2016 Miata Club
Well dig around and let us know what you find. Maybe someone else can chime in here with better advice.
| The Following User Says Thank You to JimmyMac For This Useful Post: | Nightflo (06-18-2018) |
#16 |
Drives: UK GT86
A rough idle isn't going to kill anything, but a log of it might help with diagnosis. I do wonder if it's something to do with fuel pump or fuel delivery somewhere. How's the DI ECU grounding connections?
.: Stealth 86 :.
#17 |
BoostedBRZ
Drives: Turbo BRZ
check all cold side piping and make sure everything is tight. Make sure the MAP sensor is correct (plugged in/right one) and make sure your MAF sensor is plugged in as well.
#18 | |
I’m making a list of everything to check for when I do it on my next day off. I work a ton and get 1 day off a week. If I can’t figure it out, anybody know a good shop that specializes in brz near LA?
Nightflo
Fresno, CA BOOSTED ‘15 BRZ Since ‘14 |
#19 |
Checked it, everything looks good
Nightflo
#20 |
BoostedBRZ
Drives: Turbo BRZ
dang, not sure what else to check. the only other thing is make sure the tune has the injectors scaled right and the fuel pump is mechanically functioning is all good. (i doubt the injectors are scaled incorrectly since DT is a pretty reputable tuner.)
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Nightflo (06-18-2018) |
#21 |
Drives: Toyota GTS 86
The car idles pretty much 100% on the OEM direct injectors so port injector scaling is unlikely to be the issue.
I'd be looking for a vacuum leak or bad electrical connection. |
| The Following User Says Thank You to Hags86 For This Useful Post: | Nightflo (06-18-2018) |
#22 |
Tuner said vacuum was good but I’m gonna check that again along with all my fuses
Nightflo
#23 |
Drives: 2017 Subaru BRZ
did you ever find the issue
#24 |
Interesting, we just had the same kind of problem with a new engine in the Noble. We fouled that a couple of plugs during startup and the computer saw excess o2 so it added more fuel. Making the problem worse. Disconnecting the battery to reset and putting in new plugs and the problem went away.
A lot of what if, head scratching and some language. And finally a good nights sleep before we got it. |
| The Following User Says Thank You to ls1ac For This Useful Post: | mrloko (06-26-2018) |
| Tags |
| car won't start, help me, turbo kit |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 10:35 PM |
| FR-S wont start or click... | KingLos | Issues | Warranty | Recalls / TSB | 3 | 12-02-2016 02:38 AM |
| car wont start after tune | JesseTheFlash | Software Tuning | 7 | 12-17-2014 01:43 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 02:01 AM |
| URGENT : CAR WONT START | DarkCard | Engine, Exhaust, Transmission | 9 | 08-01-2013 09:57 PM |
