#45571 |
#45572 | |
![]() How did you do that ..?? * impact wrench? * @Ultramaroon 's 24" breaker bar? * you forgot - rightsy tightsy; lefty loosey? * other? ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ichitaka05 (06-16-2018) |
#45573 |
Drives: frs
#45574 |
The Dictater
Drives: '13 Red Scion FRS
No, that's bad for lugnuts. You want them to stay put under all sorts of vibrations and forces. Antiseize will change the frictional forces that keep the lugnuts in place. It also changes the ratio between axial force and tangent force, which can damage threads and wheels if you torque it to spec. If you don't torque to spec (or reasonably close) other bad things can happen.
TLDR:. Don't use antiseize on threaded parts with a torque specification. |
| The Following User Says Thank You to Spuds For This Useful Post: | cjd (06-16-2018) |
#45575 |
#45576 | |
If you use anti-seize on lug nuts, when tightening them, you can't hear them squeak. Remember, two squeaks and a grunt is "lug nut tight". Bubba |
| The Following User Says Thank You to humfrz For This Useful Post: | Spuds (06-16-2018) |
#45577 | ||
Site Moderator
Drives: ichi 86 Project
& FYI I’ve snapped 2 more. Right now, I’m scared to loosen rear ones, cuz if this keeps up, I will snap all other ones. Quote:
I’ve heard both side of the story. I usually put lil bit on mine, but when I put new lugnuts, I didn’t, result, I’ve snapped lugnuts... even strong ARP ones. How do you make it not seize the studs & lugnuts without anti-seize. |
#45578 |
Drives: 2019 Toyota 86
So it turns out one of my closest friends from high school is gonna put Lamborghini-style doors on his Toyota 86. I think I'm going to have to schedule an intervention. He keeps insisting "It looks way better in person! Trust me!"
#45579 |
Drives: 2017 BRZ
How does one shear studs like that?! I have wheels on and off far to often and nothing... Though I'm always prepared with replacements and tools for the job...
Sucks! Kinda like this weather. This is late July/early August weather.
#45580 | |
As far as the use of anti-seize, I've been tightening nuts on wheels for going on 70 years …. and NEVER used any anti-seize compound nor have I used a torque wrench to tighten up the lug nuts. I've never busted off a wheel stud nor have I ever had a wheel come loose. My secret, two squeaks and a grunt (over the age of 70, maybe two grunts), using a tool such as this. PS - Always be sure that your lug nut wrench is lined up straight with the stud ….. like, NO jumping on it …. humfrz |
#45581 | |
Site Moderator
Also to add, I’m not frustrated at ARP, cuz they make great parts... I’m just frustrated at the timing. I just wanted to replace my brake pads, but now, I’ll be doing more work. I’ll be picking up more ARP studs & lugnuts today. I’m wondering new lugnuts caused this... or maybe I’m overthinking? I used to have Kics lugnuts and they were working nicely, but when I replace it w Muteki this happened. Either way I’ll be picking up different brand & I’m thinking Gorilla. They have forged steel, so it should be strong for daily instead of chrome Vanadium... so I hope |
#45582 |
Replace with OEM lugs and nuts. Done. I've had mine off countless times. Like new.
#45583 |
Drive From Home
Drives: BRZ STI Performance
I've used OEM and McGard all my life and no issues. Then again I don't track.
| The Following User Says Thank You to krayzie For This Useful Post: | Ultramaroon (06-16-2018) |
#45584 |
Doesn't matter.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
