| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#127 | |
The Dictater
Drives: '13 Red Scion FRS
However, more damping would reduce the energy transferred to the spring, this is bad for wheel contact under bump conditions. A spring stores and returns energy, while a damper transfers it into waste. An overdamped car will transfer too much force into moving the frame of the car up and down. The car is only acted on by gravity (let's ignore aero for now). So if the wheel is stiffly linked to the car by a high rate damper, it can only fall at the rate of gravity since that's the rate the car is falling at. The less damping there is, the less that corner of the car will move vertically. This means that the spring absorbs more of the energy, and has a more stationary counterweight to push the wheel downwards with. Also I feel like this applies lol.
| The Following User Says Thank You to Spuds For This Useful Post: | ermax (05-25-2018) |
#128 | |
For sure this thread is jacked, but the new topic is much more interesting. Hahaha |
| The Following User Says Thank You to ermax For This Useful Post: | Spuds (05-25-2018) |
#129 |
Sprung weight (the chassis) is controlled by rebound damping. Unsprung weight (wheels, suspension parts, etc) is controlled by compression damping. They are not the same (you can have a lot of compression damping and very little rebound damping for example, or vice versa).
The car was designed with certain goals in mind..."balance" is one of them. As was cost and durability. Lightweight wheels are generally expensive. If they're not expensive, they're usually not very strong. The OEM wheels were chosen as a compromise between function, durability, and cost. The same can be said of the OEM dampers. Over time, the OEM dampers have gone through some tweaks and changes...the OEM wheels in the USA did not (until 2017). Track cars CAN have a relatively comfortable ride. Properly dialed in, they can feel better than stock especially over big bumps. They might not feel as good on certain surfaces though, and often require more frequent servicing. Many track cars do not have a great ride, but often the good ones will ride better than typical street tuner cars. - Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | ermax (05-25-2018), lamawithonel (05-25-2018) |
#130 | |
The Dictater
#131 | |
Drives: '15 BRZ RA
![]() As you can see they focus more on the strength and stiffness side and they are more suited for the street too. Same can be said about the Sachs performance coilovers that have progressive springs with an average of 35.8N/mm rate front and rear. Stock springs on the latest models are in the range of 30.0N/mm front and rear, so not that much difference too. I have not regretted with any of these modifications and overall the car drives now better without any noticeable imbalance. |
#132 | |
Drives: 2017 86 860 Special Edition
What size did you buy those wheels in? |
#133 |
Drives: '15 BRZ RA
The stock wheels were 16" and I stayed in similar specs. When I changed the suspension to Zachs coilovers, I had to check that the wheels were approved by the suspension manufacturer:
![]() The camber, toe, and caster angles of the suspension were checked after the installation by DEKRA. This is how things SHOULD be and not the common local garage or shop installation. |
#134 | |
The state mandating such things seems super over zealous for anyone with half a brain. I guess it keeps the stupid masses from hurting themselves. |
| The Following User Says Thank You to RayRay88 For This Useful Post: | why? (05-27-2018) |
#135 |
Drives: '15 BRZ RA
#136 |
Only happy when it rains.
Drives: series.blue
it's totally moronic. But the EU wants everyone to look to them for absolutely everything, that way they can infantilize the populace completely.
I mean it is really hard to screw up wheels. |
| How much does wheel weight affect performance? | Slammillionaire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 89 | 07-05-2019 02:20 PM |
| 3 pound weight difference? | UtahSleeper | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 07-05-2017 12:21 AM |
| FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 08:11 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
| weight difference between auto and manual??? | sofrsnsokleen | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-22-2012 11:40 PM |
