Old 05-20-2018, 12:10 AM   #15
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
86 dct burning smell when downshifting to 1st to slow down
86 dct burning smell when downshifting to 1st to slow down. Could this be the clutches inside the dct or the tranny fluid overheating or is my excess oil leaking somewhere during the throttle bleeping? I do enjoy downshifting with this tranny.
The oil is about 1/3" over the full on original oil. Fyi
pcguru2000 is offline   Reply With Quote
Old 05-20-2018, 12:28 AM   #16
Originally Posted by Apoc View Post
It's Shake and Bake
And I helped
Old 05-20-2018, 11:47 AM   #17
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
It's Shake and Bake
And I helped
Double points awarded, and a new category created.. "NecroOff Topic"
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
Ultramaroon (05-20-2018)
Old 05-20-2018, 12:15 PM   #18
Wel to start off the car does not have a DCT nor clutches of any type in the AT. Even if it did they would not be overheating on downshifts.
If you oil is only 1/3" above the hole that isn't the issue either. As said early in this thread it is probably just the new car oil burning off. You just smell it at low speed because it isn't blowing away behind you.
Old 05-20-2018, 03:03 PM   #19
Oooo. *buzzer sound*
There are both clutches and brakes in the AT. They do heat and slip, but not on downshifts.
...or do they? Not outside the realm of possibility.
Old 05-20-2018, 03:07 PM   #20
For five long years Apoc waited in vain. Better late than never.
Apoc (05-20-2018)
Old 05-20-2018, 04:03 PM   #21
Not in the DCT sense of the word.
Old 05-20-2018, 05:21 PM   #22
Well to start off the car does not have a DCT nor clutches of any type in the AT. Even if it did they would not be overheating on downshifts.
Don't do me like that. We both know that clutches and brakes differ only in whether or not they spin. Automatic transmissions have shit tons of both, and they stink when they fail.
Just because the TCU doesn't allow the engine to overrev doesn't necessarily mean the first gear clutch/brake/whatever can't get hot from repeated hard engagement. I've never done it but if a downshift into first isn't preceded with a solid rev match, shit will eventually smoke. Ask owners of the Honda H5.
Old 05-20-2018, 05:31 PM   #23
Yes. This is a regular automatic transmission. The references I made were that it is not a dual clutch transmission and if it was it could take a downshift without smelling. At no point in time did I say an AT would not. I will give you the fact there are clutches of a sort in the AT but that does not make it a DCT of any type.
Old 05-20-2018, 05:46 PM   #24
ok we good
Leonardo (05-20-2018)
Old 05-20-2018, 06:12 PM   #25
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by radroach View Post
First ~1000 miles I had a burning smell after driving, went away but sometimes I get a harsh odor in the cabin.
He who smelt it dealt it.
The Following User Says Thank You to wbradley For This Useful Post:
spike021 (05-21-2018)
Old 05-20-2018, 07:47 PM   #26
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Hot cat.
thomasmryan is offline   Reply With Quote
Old 05-20-2018, 09:36 PM   #27
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
So the slower folks can see the awesome movie reference I did 5 years ago.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-21-2018, 04:58 PM   #28
pcguru2000
pcguru2000's Avatar
That was a great deductive thinking, but in this case it only happens when using the paddle shifters to go from 2nd to 1st. When in D mode and not using the paddle shifters to slow down, there's no smell at all.
I could have sworn it was a DCT. Don't know where I read it but I was wrong. It's just a sequential automatic. I though my car did not have a torque converter because it was a DCT but it's not and it does have a torque converter.
I also assume that the torque converter doesn't lock up from 2nd to 1st when shifting, which means there's no wear and tear in the torque converter because it's just rotating liquid correct? If yes, the wear then is all happening inside the transmission on the brakes/clutches or there is no wear and tear when shifting from 2nd to 1st and the throttle blips?
The Following User Says Thank You to pcguru2000 For This Useful Post:
Tcoat (05-21-2018)
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 05:56 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 02:31 AM
Burning smell when front defrost is turned on jlu Issues | Warranty | Recalls / TSB 14 03-08-2013 05:15 PM
Burning oil smell at idle after car warms up chris240 Issues | Warranty | Recalls / TSB 3 02-11-2013 01:33 AM
Burning oil? N/A Synack Issues | Warranty | Recalls / TSB 11 11-08-2012 07:14 PM
