Old 05-09-2018, 08:50 PM   #1
oldnotdead
Drives: 2017 86 at, OFT Tune, HKS exhaust
First Oil Change, Fumoto Oil Drain Valve
I'm interested in installing a Fumoto oil drain valve to make future oil changes that much easier. There is conflicting info online about the correct valve to use and I'm afraid I might order the wrong one. My 2017 86 is an automatic with the 200hp engine. The Fumoto site says the 2017 takes the f103 valve (m12-1.25) but it also says the earlier FRS takes the f108 valve (m16-1.5).
Does anyone know which size would be correct for my engine?
oldnotdead is offline   Reply With Quote
Old 05-09-2018, 09:29 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
Send them an email.
Old 05-10-2018, 08:57 AM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
How are you getting information that the F103 fits?
http://www.fumotousa.com/results.php...id=BRZ+2.0L+H4
The F103 is not returned in the result set when I input a 2017 BRZ.
Cliff notes: F108 is what you want.
Joon525 is online now   Reply With Quote
Old 05-10-2018, 11:00 AM   #4
oldnotdead
Yes, you are right about the BRZ, but for a 2017 86 it does return f103 so I'm still confused.
Old 05-10-2018, 11:20 AM   #5
Joon525
Joon525's Avatar
Drives: 2016 BRZ
You want the F108
http://www.ft86speedfactory.com/fumo...l#.WvRVCKQvxjE
Old 05-10-2018, 12:29 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I got the 108. Don't lose the plastic drain tube fitting that snaps on the end.
It comes with a fiber washer rather than a crush washer.
I put gasket sealer on both sides of it and didn't over torque the install.
Still working as designed. Due for another change shortly.
Being able to drain directly into empty jugs is so much nicer than messing with catch pans.
The Following 6 Users Say Thank You to bcj For This Useful Post:
Busybee (01-28-2020), gravitylover (02-18-2020), kevaughan (09-14-2025), soundman98 (02-18-2020), Tristor (05-10-2018), Ultramaroon (05-10-2018)
Old 05-10-2018, 01:35 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
F108
Old 05-10-2018, 01:51 PM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
I just put on the F108SX: New Generation Valve a couple of weeks ago. It's a new design where you can rotate the valve exactly where you want to drain the oil from.
tobin is offline   Reply With Quote
The Following 6 Users Say Thank You to tobin For This Useful Post:
Busybee (06-23-2022), finch1750 (03-10-2020), gravitylover (02-18-2020), kevaughan (09-14-2025), soundman98 (02-18-2020), Tristor (05-10-2018)
Old 02-17-2020, 09:28 PM   #9
Yellow BReeZe
Yellow BReeZe's Avatar
Drives: '17 Charlesite Yellow BRZ
Hello @ tobin! I see you put the newer Fumoto F108SX on your BRZ a couple years ago. Just curious as to how that is working out for you.
I have a 2017 Series.Yellow that I have no plans on changing ride height on. Mainly keeping it factory stock and enjoying it just the same. So not super worried about scraping the underside, but thought I'd see what your thoughts are on the F108SX.
Thanks...
Yellow BReeZe is offline   Reply With Quote
Old 02-18-2020, 07:16 AM   #10
tobin
tobin's Avatar
Drives: '13 BRZ
Thanks...
I've been very happy with it, and added one to my '06 Outback as well. It's a great product...just get one!
The Following 3 Users Say Thank You to tobin For This Useful Post:
Busybee (06-23-2022), gravitylover (02-18-2020), soundman98 (02-18-2020)
Old 02-18-2020, 11:57 AM   #11
Yellow BReeZe
Thank You..!
Thank you for your quick response. I'm ordering one momentarily!
Old 03-09-2020, 12:19 AM   #12
Yellow BReeZe
Got my Fumoto F108SX and plan on installing it at the next oil change. Thanks again for the recommendation, @tobin!!
The Following 2 Users Say Thank You to Yellow BReeZe For This Useful Post:
tobin (03-10-2020), Wally86 (06-25-2020)
Old 04-25-2021, 05:55 AM   #13
saltywetman
Drives: 2020 Toyota 86 GT 6M
Sorry for necroing this 1 year old thread but did not want to create a new thread for the same discussion. This new F108sx, it almost looks like this has the same profile as the nipple less older model but with the benefits of having a nipple that's 90 degrees rather than straight down. Anyone compare the 2 and able to confirm the new SX valves have similar clearance as the old F108 w/o nipples?
saltywetman is offline   Reply With Quote
Old 04-26-2021, 12:06 AM   #14
86TOYO2k17
Drives: 2017 toyota 86
Fumoto Original F108S FS-Series Drain Valve with Short Nippple with Lever Clip, Bronze, 16mm-1.5 https://www.amazon.com/dp/B004FFHH0M...ing=UTF8&psc=1
FS: Fumoto Drain Valve turbos86 Engine, Exhaust, Bolt-Ons 2 03-15-2017 07:41 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
SOLD - Fumoto F108 Oil Drain Valve - NEW ZZT86 Australia Classifieds 0 09-25-2015 06:03 AM
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 07:27 PM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 06:18 PM
