Old 04-26-2014, 08:28 AM   #1
viper073
Drives: Toyota 86 GTS
Exclamation Smart entry not working
Hey guys,
I recently put sound deadener in my doors for a custom stereo install, but I have since noticed my smart entry has stopped working on the passengers side. I can lock the door on the outside, but it wont unlock when I try to open the door. Drivers side works fine.
Does anyone know what controls this inside the door? If someone could point it out I can maybe trace the wires to make sure they haven't been damaged.
Cheers.
viper073 is offline   Reply With Quote
Old 05-10-2018, 12:06 AM   #2
zeroxg35
Drives: Hot Lava FRS
Pull the battery connection for a few minutes to allow the BCM to reset itself.
Otherwise - did you accidentally block some mechanical function in the door with your sound deadening?
zeroxg35 is offline   Reply With Quote
Old 05-10-2018, 12:28 AM   #3
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Thread is from 2014.
The Following User Says Thank You to KR-S For This Useful Post:
FRSBRZGT86FAN (05-28-2018)
Old 05-10-2018, 12:54 AM   #4
Subsonic
Subsonic's Avatar
A few minutes ago, there was a post #2 from a guy who has the same fault. It's since been removed.
Subsonic is offline   Reply With Quote
Old 05-10-2018, 01:02 AM   #5
KR-S
Sporadic Member
KR-S's Avatar
From this thread? Seems weird he'd remove it then.
Old 05-10-2018, 09:16 AM   #6
Found the problem so deleted the post? People on the internet are weird.
Old 07-31-2018, 01:10 PM   #7
Boog
Drives: 2018 BRZ
I'm having the same problem only on the driver's side. Opened up the door for sound deadening install as part of a speaker upgrade last week, but I'm not sure it's related since it was working for a few days after. Passenger side keyless works, and driver's side keyless lock works, but the unlock doesn't respond.
Anyone ever find a solution aside from resetting the BCM by disconnecting the battery? Not seeing anything in search.
-Boog
Boog is offline   Reply With Quote
door, smart entry, wiring
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 11:04 PM
Torque Pro Working on Parrot Asteroid Smart Brandon__ AFRICA 7 06-21-2013 12:21 PM
Keyless Entry Delay/Not Working Dezoris Issues | Warranty | Recalls / TSB 0 11-02-2012 07:57 PM
Aftermarket Push Button Ignition Smart Entry System zAnSh1n Electronics | Audio | NAV | Infotainment 75 08-19-2012 03:23 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 06:56 PM
