| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2017 86 at, OFT Tune, HKS exhaust
First Oil Change, Fumoto Oil Drain Valve
I'm interested in installing a Fumoto oil drain valve to make future oil changes that much easier. There is conflicting info online about the correct valve to use and I'm afraid I might order the wrong one. My 2017 86 is an automatic with the 200hp engine. The Fumoto site says the 2017 takes the f103 valve (m12-1.25) but it also says the earlier FRS takes the f108 valve (m16-1.5).
Does anyone know which size would be correct for my engine? |
#2 |
Sarcastic SOB
Send them an email.
#3 |
Drives: 2016 BRZ
How are you getting information that the F103 fits?
http://www.fumotousa.com/results.php...id=BRZ+2.0L+H4 The F103 is not returned in the result set when I input a 2017 BRZ. Cliff notes: F108 is what you want. |
#4 | |
#5 | |
Drives: 2016 BRZ
http://www.ft86speedfactory.com/fumo...l#.WvRVCKQvxjE |
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I got the 108. Don't lose the plastic drain tube fitting that snaps on the end.
It comes with a fiber washer rather than a crush washer. I put gasket sealer on both sides of it and didn't over torque the install. Still working as designed. Due for another change shortly. Being able to drain directly into empty jugs is so much nicer than messing with catch pans.
"I gotta rock." -- Charley Brown |
| The Following 6 Users Say Thank You to bcj For This Useful Post: | Busybee (01-28-2020), gravitylover (02-18-2020), kevaughan (09-14-2025), soundman98 (02-18-2020), Tristor (05-10-2018), Ultramaroon (05-10-2018) |
#7 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
F108
#8 |
Drives: '13 BRZ
I just put on the F108SX: New Generation Valve a couple of weeks ago. It's a new design where you can rotate the valve exactly where you want to drain the oil from.
| The Following 6 Users Say Thank You to tobin For This Useful Post: | Busybee (06-23-2022), finch1750 (03-10-2020), gravitylover (02-18-2020), kevaughan (09-14-2025), soundman98 (02-18-2020), Tristor (05-10-2018) |
#9 | |
Drives: '17 Charlesite Yellow BRZ
I have a 2017 Series.Yellow that I have no plans on changing ride height on. Mainly keeping it factory stock and enjoying it just the same. So not super worried about scraping the underside, but thought I'd see what your thoughts are on the F108SX. Thanks... |
#10 | |
Drives: '13 BRZ
| The Following 3 Users Say Thank You to tobin For This Useful Post: |
#11 |
Thank You..!
#12 |
Got my Fumoto F108SX and plan on installing it at the next oil change. Thanks again for the recommendation, @tobin!!
#13 |
Drives: 2020 Toyota 86 GT 6M
Sorry for necroing this 1 year old thread but did not want to create a new thread for the same discussion. This new F108sx, it almost looks like this has the same profile as the nipple less older model but with the benefits of having a nipple that's 90 degrees rather than straight down. Anyone compare the 2 and able to confirm the new SX valves have similar clearance as the old F108 w/o nipples?
#14 |
Drives: 2017 toyota 86
Fumoto Original F108S FS-Series Drain Valve with Short Nippple with Lever Clip, Bronze, 16mm-1.5 https://www.amazon.com/dp/B004FFHH0M...ing=UTF8&psc=1
| FS: Fumoto Drain Valve | turbos86 | Engine, Exhaust, Bolt-Ons | 2 | 03-15-2017 07:41 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| SOLD - Fumoto F108 Oil Drain Valve - NEW | ZZT86 | Australia Classifieds | 0 | 09-25-2015 06:03 AM |
| GROUP BUY: Fumoto Drain Valve | Simon99 | Mechanical Maintenance and Tools | 8 | 03-28-2014 07:27 PM |
| Installed Perrin shifter bushing & Fumoto oil drain valve | zooki | Engine, Exhaust, Transmission | 23 | 03-31-2013 06:18 PM |
