Old 05-08-2018, 03:52 PM   #71
Tokay444
Damnit doesn't anybody know of a steer by wire production car?
Nobody?
Apparently the FR86Z
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
bkharmony (05-08-2018), Tcoat (05-08-2018)
Old 05-08-2018, 03:57 PM   #72
Maybe we misunderstood the whole "steer by wire" thing?
bkharmony (05-08-2018), ermax (05-08-2018), Ultramaroon (05-08-2018), why? (05-08-2018)
Old 05-08-2018, 03:59 PM   #73
Nobody?
FRSBRZRSGTTS
Old 05-08-2018, 04:02 PM   #74
mazeroni
Drives: 2013 Scion FR-S Series 10
Originally Posted by Qwimby1 View Post
I have about 3,000 miles in the car so far and still haven't gotten used to the lack of road feedback in the steering. Or is it there and I just don't feel it? I don't think so.
My frame of reference is limited but I've read lot of journalists comment that the Twins' compare closely with the Cayman, which many rate as having the best steering out there. I've never not been happy with the steering. Perhaps there is a tad too much assist at low speed.
I think we also need to look at how the weight over the front axle, tire size, and suspension geometry affects forces going to and from the road and back through your body.
Has anyone ever replaced the rack in these cars? Gone full manual steer without any electric or mechanic buffer?
When talking steering feel, what exactly do we mean? I hear this a lot and I've never quite understood. I get loads of vibration and impact harshness through the rim. Going over uneven tarmac and elevation changes seems to affect the force of inputs required to turn the wheel. If I'm going around a bend a high speeds and have a lot of compression on the suspension on one side the steering will fight back a little. Going over wet roads or roads with dirt or sand from construction leaves the wheel feeling completely numb.
Where I will contend it falls short, and seems to be an issue for a lot of electric assist racks, is that you can "outrun" the system if you crank the wheel too fast left to right. Then when the car settles and you make slower inputs, things seem heavier. Maybe the system is stepping in to assist when doing that?
mazeroni is offline   Reply With Quote
The Following User Says Thank You to mazeroni For This Useful Post:
Tcoat (05-08-2018)
Old 05-08-2018, 04:27 PM   #75
Not really sure what experience some here have had with non assisted steering but it was/is far from all fun and games.
Vehicles that had steering with great road "feedback" that I have drove.
Hit a nickel laying on the road and break both your arms
Can go straight for miles. Turns were a bitch.
Is that a 1/2 inch wide crack in the road? OK lets just follow it and see where we go.
You want to turn while sitting still? LOLOLOLOLOLOLOLOLOL suuuuuure.
bkharmony (05-08-2018), humfrz (05-08-2018), Ultramaroon (05-08-2018)
Old 05-08-2018, 04:29 PM   #76
There is a sensor in the assist unit that detects the difference between steering wheel and column position. A spring-loaded coupling allows for a few degrees of turn either way. It can be felt when cranking the wheel with the engine off.
Hmmm... Stiffening that coupling would decrease the servo response to the faster steering input.
Tcoat (05-08-2018)
Old 05-08-2018, 04:33 PM   #77
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
FRSBRZRSGTTS
FT86FRSBRZRSGTTS
bkharmony is offline   Reply With Quote
Old 05-08-2018, 04:40 PM   #78
Originally Posted by bkharmony View Post
FT86FRSBRZRSGTTS
I was sticking with alphabetical to see how close it came to getting all the letters. Just a couple more special editions and they could make it.
Old 05-08-2018, 04:42 PM   #79
Or create a lag.
Or cause the wheel to jerk as it overcomes it.
Or simply burn out or at least overheat the servo.
Old 05-08-2018, 05:11 PM   #80
mazeroni
I'll happily drive this... manual steering and doesn't seem to be a pain in the ass despite having no assist.
humfrz (05-08-2018)
Old 05-08-2018, 06:16 PM   #81
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Apart from all this talk of wires...
I find the feel and weight of the steering (made better with quality 225 wide rubber) one of the best things about my car.
Braking, sliding, ‘powersliding’ etc are all easy to feel and modulate and I always know where the wheels are pointing and what they’re doing.
I like driving!
86 South Africa is offline   Reply With Quote
Old 05-08-2018, 06:34 PM   #82
Or create a lag.
*sigh* no
Tcoat (05-08-2018)
Old 05-08-2018, 06:41 PM   #83
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Heavy duty rack bushings and STI rack bolts make it even better. I think they did a great job. Love the steering.
86 South Africa (05-09-2018)
Old 05-08-2018, 06:54 PM   #84
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by Kaotic Lazagna View Post
Do you have Volks CE28?
I'm sure Scott can make some more.
6.5 lb. Wheels on the twins would really free up some of that crank up. Haha
yea, I was one of the crazy ones. 14x5.5.
why? is offline   Reply With Quote
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 10:12 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 03:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 05:52 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
