| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 satin white brz limited
I have the torrin double lock ones your linked. Have worked great for 2 years now
#16 | |
The Dictater
Drives: '13 Red Scion FRS
#17 |
Drives: '22 WRB
All you need is the 1.5 ton aluminum low-profile jack from Harbor Freight and their jack stands. I've been autocrossing for 11 years now and have never used anything but those. Cheap, light, and work great.
#18 |
The Gunshine State
Drives: '14 BRZ Limited
^ What he said, simple and works (although HF jacks only last me a few years before needing replacement).
![]() Current DD: M235i |
#19 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Another vote for the ESCOs. In terms of strength, they are over kill for the BRZ, but their stability is hard to beat and I have no interest in trying bench press a 2700 pound car. If there's a place to cheap out a little, it's on the jack. I'm in the harbor freight camp on those. Just make sure it's one of the low(est) profile models.
Slow is smooth, and smooth is fast
#20 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
btan219,
Sorry I'm late in the game here, maybe will be help for others... These notes are my opinion having been an auto tech for years, having also worked on vehicles at home: The jack you showed would be a pia to use on a regular basis. Any floor jack which requires putting the metal handle in one place to raise the jack, in another place to lower the jack is a stupid design. Also that hollow, thin handle will bend at it's end becoming useless. Though unlike the one you gave a link to, any floor jack which has a roller in the front instead of wheels is dangerous. That type of jack will easily tip over in use. A floor jack needs to have four wheels, not two. I would suggest spending the money and getting an aluminum jack. There will be times you wanna put the jack in the trunk of a car, to move the jack. Much easier to lift a jack which weighs less. A steel jack is much cheaper yet very heavy to lift. A steel jack can be had for around $100. if that's all you have to spend. Pay attention to the minimum lift height of any jack before purchasing it. My current jack has a minimum lift height of 3 3/4 inches and barely fits under the front center (radiator core support) of my car. I must lift the front of car slightly to get the jack under there. A lesser minimum lift height would be even better. Make sure you know exactly just where to lift front of car...bottom of radiator core support...best place to lift for oil and filter changes...requires you slide jack under front of car, then crawl your body under there to find exact proper placement of jack before lifting...very little room for error here ! http://www.ft86club.com/forums/showthread.php?t=10111 I am currently using a 3 ton Aluminum floor jack from Harbor Freight, cost was close to $200. (currently $160. with coupon) yet gets the job done. Makes sense to spend the money now for something which will save over a period of numerous oil and filter changes, tire rotations in the future. The jack stands you picked look just fine for the money. Best to have four jack stands available, not two. Harbor freight makes soft plastic covers for top of jack stands, they work well to protect pinch weld area bottom of rocker panels. Last edited by ToySub1946; 05-07-2018 at 03:04 PM. |
#21 |
Drives: DGM 15' BRZ Limited
Thanks for the advice everyone. I think I'll be going to Harbor Freight in the next few weeks to get a floor jack. Looking at these:
https://www.harborfreight.com/automo...ump-61282.html https://www.harborfreight.com/automo...ump-61253.html Anyone know what the difference is? They look exactly the same |
#22 |
^^ Good call. You will like that $97 jack better than a small trolley jack.
Looks identical to me. |
#23 |
Yes those model steel floor jacks seem to be a good pick. Also model 62326 seems to be same specs. Quite normal for Harbor Freight to use various model numbers for exact same merchandise. Those three models currently listed for $97.99 Best to get on a harbor Freight mailing list... You may also find an in store coupon. Now I see a 'super coupon' in a current mailer to me for $79.99 for those exact three models of floor jacks...through 6-30-18.
All have minimal height of 2 7/8" and maximum height of 19 3/4", great for this car's needs. Last edited by ToySub1946; 05-07-2018 at 11:32 PM. |
#24 |
Thanks
If you don't own a jack already I would opt for a 2 ton at least. I have the 1.5 to take to the track and it works fine but you feel it working compared to higher capacity jacks. Also if you aren't on one of those smooth garage floors it doesn't roll that easy when you start jacking.
#25 | |
Drives: 18 BRZ tS
#26 | |
Drives: 2017 BRZ series.yellow
If it is the same jack, the reach is good, but not quite enough to hit the front center jack point on my lowered BRZ. I just drive up on a couple 2x4's and then no problems. |
| The Following User Says Thank You to Breezio For This Useful Post: | cjd (04-12-2021) |
#27 |
Drives: 2017 BRZ
Yeah, I need an extra inch or so of clearance up front with the STi lip and my car in race trim. Can shove it under in a pinch.
#28 |
Be Kind
Drives: 2020 86
Quickjack 5000slx. Totally fits under a lowered car, has built in mechanical safety locks, and goes up in less than 30 seconds.
| The Following 6 Users Say Thank You to Wally86 For This Useful Post: | Busybee (04-15-2021), Capt Spaulding (04-12-2021), MuseChaser (04-13-2021), NoHaveMSG (04-12-2021), RToyo86 (04-13-2021), Tcoat (04-12-2021) |
| WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-27-2015 12:03 AM |
| Custom made Jack stand supports | AlexTheGreek | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 03-04-2015 06:01 PM |
| jack stand body contact behind pincheld | tjc5268 | BRZ First-Gen (2012+) — General Topics | 2 | 04-12-2014 05:15 AM |
| Jack stand points | xxscaxx | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-12-2013 10:01 PM |
| Jack/stand system | Mr.Corvus | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 03-31-2013 01:02 AM |
