Old 05-02-2018, 06:13 PM   #351
tomm.brz
Drives: brz 2017 hksv2
oh yep i meant right that with better definitions
tomm.brz is online now   Reply With Quote
Old 05-02-2018, 08:18 PM   #352
JIM THEO
Drives: BRZ 2018
Are V4 tunes available for EUDM 2018 manual BRZ as it has different calibration ID from USDM cars?
Shiv are you there?
JIM THEO is offline   Reply With Quote
Old 05-02-2018, 08:46 PM   #353
steve99
Drives: FT86
Shiv are you there?
no not yet V4 only officially released for USA cars.
If you know calid of your car can probably sort tune for you
Old 05-03-2018, 06:51 AM   #354
JIM THEO
Drives: BRZ 2018
I am waiting my new Tactrix cable and I'll tell you for sure, I can send you my original maps for base although I'll probably buy an OFT in the near future.
Thanks in advance Steve!
Old 05-03-2018, 03:18 PM   #355
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
P2270 is not a "normal " code you would expect from removing a cat.
https://www.obd-codes.com/p2270
That code indicares you have a real problem like exhaist leak or bad o2 sensor or incoreectly installed front 02 sensor and it constantly reading lean afr.
If you getting that code you would also expect to see high positive fuel trims.
P0420 is the code for cat efficiency.
Post up a log of tune
With parameters below cruise idle and a wot run to redline
V4 tune iam intial is set to 0.7 so each time car stopped it resets to 0.7
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR / Target AFR
STFT (percent)
LTFT (percent)
Oil Temp (F)
CL/OL / Fuel Sys Status (2 = CL, 4 = OL)
IAT / Intake Air Temp (F)
IAM / Ignition Advance Multiplier
FLKC / Fine Learning Knock Correction (degrees)
well I win dumbass of the day award. Looks like when I first installed my UEL headers I put in a o2 spacer on the rear o2 bung to try to drive a bit on the stock tune. I never went back and removed it after using the OFT. Haven't tested yet but I'm sure that's the culprit. Also looks like there is a v4.03 for k00c now so I will load that in too.
I'm used to corvette world where we just tune out or turn off the rear o2 sensors and you can leave them in or take them out. Looks like on these cars they must still serve another function besides checking for a cat efficiency correct me if I'm wrong.
Thank you everyone for steering me in the right direction
SuperTom is offline   Reply With Quote
Old 05-05-2018, 01:27 AM   #356
nofferman
nofferman's Avatar
I'm trying to go from v2.061 tunes to v4 tunes on my '13 manual BRZ (CAL ID ZA1JA01C), but I've been having a beast of a time getting the tablet to load the new maps.
Every time I try to upload a file, I'm getting the DEV121.dll message about the checksum being wrong. I followed the support guide for that error, but it's the same every time I try to upload a ROM. Tried older v2 ROMs and new v4 ROMs and four different PCs, with various versions of Win7/Win10 and I keep seeing it. I've been in contact with Anthony from OpenFlash, but we've not found a fix yet.
I have an older v1 tablet that hadn't been updated in a couple years; could there be some data problem with the tablet that's preventing me from loading new maps?
I was able to load my stock ROM tonight, would erasing the tablet and starting from scratch be worth trying?
Thanks all!
nofferman is offline   Reply With Quote
Old 05-05-2018, 02:34 AM   #357
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
I changed the ignition timing post start to -18.95 (wouldn't let me change to -19 for some reason) and changed all the idle entries on tables A to F from 1200 to 1400 but I am still not getting a loud cold start. Car has been sitting for 4+ hours and the temperature outside is 13 deg C (55F). Perhaps I am missing something or maybe its just not cold enough outside?
Originally Posted by tomm.brz View Post
if you only change ignition timing post start, will be louder but not like stock
stock cold start is very loud also because has higher idle so if you want it loud rise it like at 1400 rpm minimum, on the "left" zones of the idle maps
v4 tunes has max of 1200rpm that s not much to get it loud
but yes, it s basically only that, try put -15 or -19 (this one is on my17+ stock rom) and hear it
but v4 has maf correction after start a lot reduced on cold start, you should put higher values on the first 2 rows in those 2 maps, but v4 oft definitions have them not defined, you need better definitions to modify them
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 05-05-2018, 04:55 AM   #358
tomm.brz
in ots tunes af#3 (=rear o2 sensor corrections regulations ) are still enabled at stock values (+-50%), you could just put them at 0 and it just stop working
but steve said that CEL is relative to FRONT o2, not the secondary one
so if you have that cel, you need to control afr and check for leaks
Old 05-05-2018, 05:00 AM   #359
tomm.brz
not cold enough relative to idle maps you have, but i suspect it s because of the maf correction after start maps
did you touch them? v4 "flats " them, you need to increase each value in the first 2 rows
maybe the idle is still not high enough, try to raise it depending on the ambient temperature you are getting now.. maybe copy stock subaru values
use the definitions steve provided to us in the first post to be able to see the maf correction after start maps
Old 05-05-2018, 09:29 AM   #360
SuperTom
SuperTom's Avatar
That's where my confusion is coming from. By definition P2270 Is Bank 1 Sensor 2, which refers to the post cat sensor.
I did check the tightness of everything down there. I an very usually very careful about putting the sensors in the same hole they came out of on the stock headers. I will double check the part #'s to make sure they didn't get switched.
Old 05-05-2018, 10:46 AM   #361
tomm.brz
try to disable af#3 corrections and check (log) afr maybe?
Old 05-05-2018, 11:05 AM   #362
FT86Z
Drift noob
FT86Z's Avatar
No sir, just changed idle speed targets. Where can I find these fields to change? I started the car up this morning and the revs shot past 1600 rpm for a second, then dipped below 700 rpm then finally sat at around 1300 rpm. I turned the car off after a minute, turned it back on and it sat at 1400 rpm. It's a tad louder than before but i wonder why it dips like that?
FT86Z
藤原とうふ店
Old 05-05-2018, 11:13 AM   #363
tomm.brz
are you using the definitions steve posted in first post?
you find the two maf corrrection after start in the mass airflow section
in v4 the first 2 rows are same as the other rows..from 8 to 4
you want maybe to start 15 and finish with 5 or 6
then maybe do a blend with stock values in idle tables to rise it a bit.. the higher the idle speed is, the louder it will be
FT86Z (05-06-2018)
Old 05-05-2018, 07:14 PM   #364
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
I just got an OFT 2.0 for my 2018 tS. However, I do not see a calibration file for my car from the website.
"ZA1JN10C"
How can I get a OTS tune that is compatible for my 2018 tS?
SkyeHack is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
