Old 04-28-2018, 11:45 AM   #1
zizon93
Drives: GBS
clear sidemarker is getting loose
I bought a clear sidemarker about an year ago from amazon and now it starts to getting really loose and pop off time to time everytime I fixed. Should I just buy new set of clear sidemarker from ft86speedfactory since they are claim that their fitment is same as OEM from factory. It's kinda expensive ($95) but if it is truly the OEM factory fitment then I might consider buy for it. Thank you in advance!
zizon93 is offline   Reply With Quote
The Following User Says Thank You to zizon93 For This Useful Post:
Irace86.2.0 (04-28-2018)
Old 04-28-2018, 12:12 PM   #2
DrButtDrugs
yerp
Drives: 2015 WRX
Get some 3M sticky pads on that sucker
DrButtDrugs is offline   Reply With Quote
Old 04-28-2018, 12:18 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Or hot glue gun
Old 04-28-2018, 04:17 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
First off, thank you for saying loose and not lose.
Next, I used a writeup @zeal86 wrote. Essentially you drill a hole in the plastic housing of the light then use a small gauge wire to tie a knot at that spot and run the wire to a hole off the frame. I used a wire to make a loop then I used zip ties so I could cinch it tight. It worked perfectly.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zeal86 (04-28-2018)
Old 04-28-2018, 04:20 PM   #5
norcalpb
norcalpb's Avatar
I had Helix for 3 years before they split in half, and yes the JDM ones have MUCH better fitment and a nicer material. When you tap on the plastic you can tell it’s OEM.
By having a better fit, it’ll put less stress on the notoriossuly fragile A clip and you’ll have them looking fresh for much longer.
Old 04-28-2018, 04:22 PM   #6
Irace86.2.0
PS, I think I drilled two holes like a front and back thing to get it to sit evenly.
Old 04-28-2018, 04:24 PM   #7
Irace86.2.0
http://www.ft86club.com/forums/showthread.php?t=119974
@zeal86 This is his writeup.
zizon93 (04-29-2018)
FS: OEM JDM Clear Sidemarker Lenses - SOLD chermo12 Canada Classifieds 0 06-24-2017 07:17 PM
FS: GCS Clear Sidemarker Lights ltdanko Exterior Parts (Aero, Lighting, Etc.) 7 06-22-2016 04:55 PM
DIY loose sidemarker quick fix Grip Ronin DIY (Do-It-Yourself) Guides 12 11-14-2014 03:47 PM
Sidemarker and Sidemarker Light arm broken off while driving. CreinCrein Issues | Warranty | Recalls / TSB 4 05-20-2014 09:49 AM
JDM clear sidemarker fitment issues D1cker Cosmetic Modification (Interior/Exterior/Lighting) 6 07-27-2012 04:44 PM
