Old 07-10-2012, 10:15 PM   #1
ayau
Drives: Some rust bucket
Swapping for clear side markers
This tutorial will allow you to swap your stock amber side markers for clear side markers. You can also use this tutorial to change your side marker bulbs if they ever burn out.
Warning: You may end up bending your stock amber clips after performing this tutorial, but you should be able to bend them back. I have not tried putting the stock amber side markers back on to see if they will fit tightly.
What you'll need:
JDM clear side markers
Sylvania 194NA amber bulbs
Phillips screw driver
flat head screw driver
1. Turn your steering wheel all the way to the right if you're changing your left side marker. Turn your steering wheel all the way to the left if you're changing your right side marker.
2. Remove the 4 clips holding the wheel well liner with a phillips head screw driver.
3. After you remove the liner, wrap the tip of your flat head screw driver with some tape. You'll want to do this to minimize marring up the inside of the fender.
4. Take the flat head screw driver and stick it in the hole circled in red. Push forward then inwards towards the car. This is the hardest step and will take some patience. You may need to use a little force to pry the metal clip out of the hole.
5. Once you have the amber side marker removed, twist off the stock bulbs and replace them with amber bulbs if you're going to replace your amber side marker with clear ones.
6. Once you have the bulbs locked in place, all you have to do is push the side marker back into position.
7. Repeat your steps for the other side marker.
Finished:
Old 07-10-2012, 11:00 PM   #2
Khalis
Khalis's Avatar
Drives: 2013 Ultramarine 86
Thanks for the write up. Although 3 days too late for me haha. Do you think I could use an amber led bulb instead without any problems?
Khalis is offline   Reply With Quote
Old 07-10-2012, 11:26 PM   #3
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Thanks for this! I've got my clear side markers coming in the mail and was looking for a write up like this for the past couple days (thought I was going to have to write it up myself!) I wasn't sure about the bulbs, but now it looks like I'll be ordering some chromed amber bulbs for these as well, since I already have the chrome bulbs for the front and rear turn signals. Don't want any yellow showing when the lights aren't on.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 07-10-2012, 11:36 PM   #4
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
I changed my sidemarkers to JDM clear this past weekend and bought 2 "yellow" but the color is really "amber" leds from mengmotorsports.com. They look really good at night and these led"s are made to withstand all weather unlike some led"s that you can buy. They match the color of the signal/parking light bulbs on my FR-S.
mdf4uk is offline   Reply With Quote
Old 07-10-2012, 11:40 PM   #5
mdf4uk
The led"s from mengmotorsports are in a silver/chrome casing so you do not see any yellow through the clear sides
Old 07-11-2012, 12:13 AM   #6
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
That looks spectacular, and thanks for providing a nice write up of this.
BRZerhood & FR-Society
Chupacabra is offline   Reply With Quote
Old 07-11-2012, 02:03 AM   #7
WWEVOX
Drives: White Lancer Evolution X
Which mengmotorsport lights are they? The wedge type led in yellow?
WWEVOX is offline   Reply With Quote
Old 07-11-2012, 02:39 AM   #8
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-11-2012, 03:36 AM   #9
mdf4uk
These are the ones i used in my clear side markers:
http://stores.mengmotorsports.com/-s...led/Detail.bok
Old 07-11-2012, 12:52 PM   #10
Zxtole
Going to order these soon! Is the bulb under the markers amber colored? I'd hate to take all the time on this delicate part only to have to take it off again to change the bulbs to chrome.
Zxtole is offline   Reply With Quote
Old 07-11-2012, 01:07 PM   #11
ayau
your side markers should glow orange when they're on.
the stock bulbs are white, but the side markers are amber.
if you swap in the clear side markers, then you'll want to replace the stock white bulbs with some amber #194 amber bulbs.
Old 07-11-2012, 02:28 PM   #12
Zxtole
Sounds good, thanks for the reply.
Old 07-11-2012, 06:00 PM   #13
empower-auto
Kouki-Monster
empower-auto's Avatar
Where can a guy find the clear sidemarkers?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-11-2012, 09:41 PM   #14
ayau
i bought mine from japanparts.com
you can also look at the vendor section on this forum. a couple of them are selling them as well.
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 10:56 PM
** Toyota Japan FRS and BRZ Clear Markers, Emblems and more ... ** Carson Toyota Exterior Parts - The Rest 308 04-02-2013 11:03 PM
before and after clear markers DEC1 Cosmetic Modification (Interior/Exterior/Lighting) 28 07-07-2012 05:36 PM
FR-S / BRZ side markers interchangeable? Slant Cosmetic Modification (Interior/Exterior/Lighting) 2 06-30-2012 07:26 PM
