Old 04-18-2018, 01:39 PM   #169
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Next: unsuspended rotating mass
vs: static power and body weight
Tcoat (04-18-2018)
Old 04-18-2018, 04:00 PM   #170
None of these discussions are of any value without Suberman/Ubersuber/Gforce involved anyway.
Old 04-18-2018, 04:32 PM   #171
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by ZDan View Post
I'm on the verge of deciding between running 225/45-17 on 17x8 or 245/40-17 on 17x9 for track events this year, and honestly I doubt that there's more than a tenth or two difference, all else equal. But I might go 245s based on vanity...
My 0.02, FWIW...
Having ran 215-255 wide tires and 7, 8, and 9" wide wheels.. 100% based on feel, feedback and to a small extent, the lap times. I like 225 (RS-3 v1 225/45/17 tires to be exact) on the 8" the best. The 215 rs-3 on stockers a close second.
The 17x9 et 35 with 255/40/17 are best looking 'stance' doe.. getting a lot of compliments and nods from parking lot 'car guys'
Intent > Content
The Following 4 Users Say Thank You to solidONE For This Useful Post:
Leonardo (04-18-2018), nikitopo (04-18-2018), rvoll (04-18-2018), ZDan (04-18-2018)
Old 04-18-2018, 06:15 PM   #172
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are these results on a stock car? Keep in mind that the original post was comparing nearly stock engine performance cars (i.e., stock header, exhaust, tune).
Old 04-18-2018, 08:41 PM   #173
Iceman
Iceman's Avatar
Drives: GT86
Useless comparison with so many differences between both cars.
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
Old 04-18-2018, 08:49 PM   #174
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
When running the 225's, do you have any preference on offset from a performance POV? Flush may look good but not perform any better. And why 8" when 225/45's are ideally put on 7.5" rims as identified by the tire manufacturers. And yes, I know the manufacturer's say that 225/45's can be put on 7-8.5" rims. My guess is that it really doesn't make much difference as long as it is in that range. Your thoughts?
rvoll is offline   Reply With Quote
Old 04-19-2018, 02:17 AM   #175
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The first car is better. If both cars were equal and only variable was the wheels and tires, my bet is that the difference will be even larger.
Old 04-19-2018, 03:44 AM   #176
solidONE
solidONE's Avatar
Header and tune with and without suspensions mods. otherwise pretty close to stock.
I don't think it makes much of a difference in terms of outright grip running the same 225/45/17 tire on a 7, 7.5 or 8" wheel. Though a stretched tire tend to offer a bit more firmness and the pinched tire will tend to 'give' a bit more given the same tire pressure.
I've also recorded faster laps (slightly) using stock wheels and 215 rs-3 tires with and without suspension mods. It's hard to say which is actually 'faster' but I do like the way the car behaves and the feedback I get on sticky 215 and 225 tires. But who knows? Maybe I'll like a 235 on a 8.5" or 225 tire on a 7.5" wide wheel even better? I've never tried. For now I swap between 235 (both 40 and 45 series) on 9" RPF1 or stock and 215 tires. I traded the 17x8 et45 RPF1 for my current 17x9et35's. I kinda regret going wider, but it definitely looks beefier with the 9" wheels. In terms of weight.. stock wheels and 215 are likely the heaviest.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
nikitopo (04-19-2018)
Old 04-19-2018, 11:28 AM   #177
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by mrg666 View Post
I am not aware, did anybody say that? I think the "crowd", as you call them, mainly thinks that wider looks better. I haven't seen anybody looking at those skinny tires with admiration and telling each other how smart their owners should be and they should know something that everybody else missed. You guys are not that smart, "crowd" is not that stupid. Just install those wide tires and you will feel better, I promise.
several people have. The looks crowd really isn't germain, even though one can hope to try and get them to not buy the biggest 18" wheels and tires they can cram onto the car.
Has nothing to do with who is smart. It has to do with having a conversation and exchanging ideas. It seems most people that track twins have decided 245 or 255 17's are the way to go. While the larger auto community is all trying to cram at least 18's on everything, including lightweight cars like the miata and the twins. It is worth having a discussion about even smaller wheels and tires. When the miata came out, and even through the nb, many miata owners would run 13's on their vehicles for autocross and track. In the rest of the world the twins come with 16's, and lots of rally subarus run 15's.
It is always beneficial to bring up different ideas and whether or not they are still valid for the application of the vehicles people are using.
Originally Posted by RayRay88 View Post
Please don’t put words in my mouth because you lack reading comprehension.
I suggest you re-read all my posts. Especially my last. No where did I say that you should slap on 305’s on a stock twin and you’ll turn better lap times. Does the 305 provide more lateral grip? Absolutely. Hell if you have a twin capable making use of 305’s on the track then hats off.
I was merely trying to clarify why wider tires are better on a road course. But along with every statement I qualified it with all things being equal and that there is a point of diminishing returns on each individual vehicle/setup.
The fact that you feel you need to insult just proves you don't know what you are saying. You should see ZDan's post, I have a feeling he is saying what you wish to say, but actually can write.
I wouldn't dare go anywhere near that vacuous sack of air you pretend is a functioning brain. I would fear for my life that I would catch your complete and total ineptness at communication in all its forms. The drivel you call writing wouldn't pass muster from a 6 year old, nevermind an actual intelligent adult trying to have a conversation.
Originally Posted by fatoni View Post
My confusion comes from The fact that he's using this to make a case for a smaller wheel and tire and that's the part that is confusing me.
A smaller, lighter wheel and tire does not necessarily mean a smaller contact patch or less grip. It does mean the suspension has to do less to keep the smaller mass of the wheel and tire where it wants, and that the engine can use its power and torque more efficiently and to greater effect. It is the same reason NA and NB maita's use to run 13" wheels and tires.
All else equal, within a reasonable range, wider tires will generally give more lateral grip for reasons of contact patch shape, how it deforms under lateral load, and how that affects grip vs. load curve. Additional grip *by itself* would make you faster. The only question is where is the point of diminishing returns vs. heavier wheels/tires, aero drag, and rolling resistance. Here's what I think:
Additional aero drag from wider tires is going to be pretty damn small. Difference in vehicle frontal area with 245s vs. 215s at stock ride height is about +0.005 or one half of 1%, nothing. Coefficient of drag will be slightly different as well, but considering that the 245s will put the outside surfaces of the wheel/tire closer to the profile of the body it's possible that wider wheels/tires on stockish wheel offsets might actually reduce Cd, but either way it's going to be a small difference within a reasonable range of widths.
Rolling resistance is theoretically *less* with wider tires, as a wider/shorter contact patch undergoes less hysteresis. Tires with a narrower/longer contact patch have to have more deformation in the middle of the tread and hence lose more energy while rolling. On the other hand, wider tires with a greater mass of rubber being deformed could tilt the advantage in the other direction... In practice for a reasonable range of tire widths this effect is going to also be very small.
Additional rolling resistance due to *adhesion* (sticky rubber not wanting to let go of tarmac) is not really going to be a factor on the street on street-compound tires as in those conditions the tires don't get hot and sticky. At the track it could be a factor in lap times for low power/weight cars like the FT86 and Miata, but due to the nature of how the tire deforms I'm not sure it wouldn't be *worse* for narrower tires vs. wider. The narrower tire with longer contact patch is having to be "unpeeled" from the ground over a longer circumferential distance vs. wider tire with shorter contact patch.
The biggie in terms of how going too wide on wheels/tires can hurt you in terms of performance has got to be WEIGHT. More rotational mass will hurt acceleration of a modest power/weight car, and at some point this will hurt lap times more than increased lateral grip from wider tires helps.
In reality *other factors* have a MUCH greater impact on performance, to the point that it's difficult to isolate the effects of *only* going wider on wheels/tires without changing tire diameter and/or the stretch/pooch of the tire on the wheel (inherently an issue as tire widths are in 10mm millimeter increments and wheel widths are in 1/2" increments!).
My 0.02, FWIW...
well said
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Old 04-19-2018, 12:00 PM   #178
Jordanwolf
Rice King
Jordanwolf's Avatar
well said
Why throw shit at shit?
If it smells like shit, looks like shit and tastes like shit, it must be shit. Good thing you stepped on that shit????
You shouldn't act as if you're better than him when you feel the need to also insult him. I get that it was targeted at you, but it's really not the correct approach based on that paragraph of being an "intelligent adult".
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
RayRay88 (04-19-2018)
Old 04-19-2018, 12:11 PM   #179
fatoni
well said
miatas used to be slower as well. i get why weight is of concern and im not talking about the height of the rim. never have been. if we look at that miata for example, 9" wide rims are the fastest on a road course all else equal on a stock powered na or nb.
Drive upgrades. Don't buy them.
Old 04-19-2018, 12:23 PM   #180
RayRay88
Drives: 2017 86 860 Special Edition
Exactly,
A lot of those miata's used the smallest diameter wheels they could fit on their brakes for weight savings, but they were incredibly wide (8-10").
On this point I may be wrong, but it's possible that casting technology didn't make relatively light, cheap wheels too common at the time?
I find there are a lot more options for lightweight non forged wheels at a reasonable price now than 10 years ago.
RayRay88 is offline   Reply With Quote
Old 04-19-2018, 12:52 PM   #181
Jordanwolf
Rice King
Jordanwolf's Avatar
Exactly,
720 form there definitely are more options. These are dumb cheap for us Canadians, got a full set for $800~ taxes in.
Glorious Honda.
Old 04-19-2018, 01:25 PM   #182
Icecreamtruk
Drives: Track preped NA FRS
I cant believe this thread is still going and people are still spewing non sense. Let me try to add some more fuel, maybe we can get some more entertainment out of it.
Contact patch area doesnt change regardless of tire and wheel size, only pressure on the tire and the weight of the vehicule matters.
Contact patch shape changes becoming larger (wider across the car) with a wider tire. Wheel size (within reason) affects sidewall deflection, not contact patch.
Nobody has mentioned heat. How do you expect to put heat into a 255 tire on a stock power, stock aero twin running tracks with straights that are miles long? (Fuji style of tracks). Many people dont realise that a tire that is under or over heated will not perform at its highest, yet nobody seem to care?
You choose your tire width for the track, level of aero and level of power the car you are running have, to be able to keep the tire in its optimal temperature range when pushing constantly.
Alright im done, flame away you haters. (im not naming anyone and certainly not addressing everyone, dont want to make this a personal matter).
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
krayzie (04-22-2018), nikitopo (04-19-2018), NoHaveMSG (04-19-2018)
What am I missing with all the ultra-wide wheels & tires? Vdub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-14-2017 09:08 AM
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 01:14 AM
Tires that run wide or narrow switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 12-08-2013 04:55 PM
I have a 18x7.5+38 wheels..How wide can i go with tires Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2013 01:04 PM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 09:38 AM
