Old 04-17-2018, 03:06 PM   #141
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by nikitopo View Post
Yes but more mechanical grip doesn't make you ALWAYS faster given that power is the same.
Yes we know. I have never disagreed with this statement. It's the way you presented the information.
2 cars setup vastly different with two different compound tires and drivers of unknown skill differences. The diameter of the tires are even different.
Icecreamtruk In todays topic: a bunch of people who have no idea how grip works and some who do (at least partially) but get flamed for trying to share the knowledge.
Grab your popcorn, and start from page 9.
This thread has been great from the start.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Icecreamtruk (04-17-2018), Tcoat (04-17-2018), Tristor (04-17-2018)
Old 04-17-2018, 03:24 PM   #142
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
Originally Posted by RayRay88 View Post
Ofcourse, but the original argument stemmed between track testing of two different widths. Generally speaking a wider tire gives more mechanical grip than a narrower tire of equal construction and compound.
This is a myth and is just not true. I've had a number of track experiences where the narrower tire was faster. The tire/wheel combo is one where the ONLY way to find out is to do a real world test. Adhesion is a combination of contact patch and contact pressure -- not just contact patch. Wider tires have less contact pressure. In addition, it is a function of the majority of directional forces. So for autocross, where you are exerting a lot of lateral forces, wider is generally better because of the squarer contact patch and the forces against that patch. On a road course, or on the road in general, where 95% of the travel is just forward, and not turning, the narrower tire tends to be faster because it is generally lighter and there is less drag. Have you ever seen a dragster with wide front wheels? On the other hand, if you have to put a lot of hp on the driving wheels (something that is not necessary with the Twins), then wider ON THE DRIVING WHEELS makes sense as you are putting more rubber on the road during acceleration. However, once you are at speed, those wider tires are a negative. None of this takes into account other factors like mpg where narrower tires are clearly better.
There are no simple axioms that can determine what is better. Manufacturers spend a lot of time getting balance for their cars and once you significantly deviate from that balance, you cannot be sure of the results.
rvoll is offline   Reply With Quote
The Following 2 Users Say Thank You to rvoll For This Useful Post:
nikitopo (04-17-2018), Tristor (04-17-2018)
Old 04-17-2018, 03:55 PM   #143
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
JazzleSAURUS (04-18-2018), JimmyMac (04-18-2018), mrg666 (04-17-2018), new2subaru (04-17-2018), Racecomp Engineering (04-17-2018)
Old 04-17-2018, 03:57 PM   #144
RayRay88
Drives: 2017 86 860 Special Edition
You seem to be running in circles. I was quite clear from my first comment that this was all related to circuit racing. You keep bringing up daily driving to argue your point.
Let me try to simplify.
All things being equal on a track.
Wider tires will generally give you more lateral G.
This does not take into account drag, weights or temperature.
In terms of contact patch pressure, it's not that simple. Rubber is deformable and so is the contact patch so tires can't be simply looked at as F=ma or even F-mu*r.
Contact patches remain relatively the same for both wide and narrow tires of equal compound and construction, the wider one will have a wider and shorter patch, and the narrow one will have a narrow taller patch. Wider contact patches create more lateral force per slip angle than a narrower patch. Simple.
The balance is about finding the point of diminishing returns, where you try to see how wide you can go before one or more of the mentioned variables start overcoming the increase in lateral grip.
I suggest you read up on tire load sensitivity. Your real world experience is limited to your knowledge about what is actually happening to your tire.
In response to your drag racer theory, funny cars actually require tall narrow tires for the longest possible contact patch (tall narrow patch is always better for linear acceleration). Why do they still use huge wide tires? Because tall narrow tires can't cope with the heat 5000hp puts into them.
Also I question anything you say simply based on the fact that you think a road course is 95% forward travel. Maybe you mean drag racing?
RayRay88 is offline   Reply With Quote
The Following 3 Users Say Thank You to RayRay88 For This Useful Post:
Icecreamtruk (04-17-2018), mrg666 (04-17-2018), Tristor (04-17-2018)
Old 04-17-2018, 04:09 PM   #145
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Huh?? I think we need to back up a sec and rethink what was said. There is a constant disconnect between what is quoted vs the argument being made.
RayRay88
This is absolutely true, up to a point obviously. If you have evidence to prove otherwise please present it, but in general this is a genuinely accepted fact.
Then we go to your second line.
That is not what is being argued by RayRay88. He only commented on the lateral grip capability of a wider tire.
No one is disagreeing with this statement. We can break down this thread to simply say "more lateral grip does not always equal improved lap times." Then of course we wouldn't have this 11 pages of glory
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
gtengr (04-17-2018), Icecreamtruk (04-17-2018), Tcoat (04-17-2018), Tristor (04-17-2018)
Old 04-17-2018, 05:37 PM   #146
fatoni
Can you explain this?
Drive upgrades. Don't buy them.
Old 04-17-2018, 05:45 PM   #147
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Tires hold cars off the ground by volume, not pressure (at least, not directly). A larger tire has more volume than a smaller tire at the same pressure, so increasing the tire size on a vehicle means you need less pressure to achieve the same load capacity.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Old 04-17-2018, 05:56 PM   #148
RayRay88
100% true. The only thing he fails to grasp is that contact pressure, for two equal tires of different widths, really only starts to truly matter when you’re talking about snow or rain where you want as much pressure dowards to cut through whatever medium you’re driving on. Hence why rally vehicles have super skinny tires. On the pavement contact patch deformation and shape dictate lateral grip the most.
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 04-17-2018, 06:06 PM   #149
fatoni
it can change the pressure per square inch but not the pressure. if a car weighs 2800lbs, its going to exert 2800 lbs of pressure on the ground no matter what the tire volume is.
Old 04-17-2018, 06:42 PM   #150
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I think it is a good discussion
The Following User Says Thank You to nikitopo For This Useful Post:
NoHaveMSG (04-17-2018)
Old 04-17-2018, 07:07 PM   #151
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I think it's at least as inaccurate to say that a 300 width would actually give more mechanical grip to begin with.
and yet that is absolutely what the wider tire is always better crowd is arguing. Of course it is absurd.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Tcoat (04-17-2018)
Old 04-17-2018, 07:09 PM   #152
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Pressure is defined as force per unit area (lbs/in^2 or N/m^2). You're describing 2800 lbs of force to the ground, not pressure. Saying "pressure per square inch" is like saying (lbs/in^2)/in^2 or lbs/in^4 which is not a unit of pressure.
Pressure is inversely proportional to the area so if you apply the same amount of force (2800 lbs) to a smaller area, pressure goes up:
2800 lbs/area (in^2) = some pressure (psi)
2800 lbs/smaller area (in^2) = some bigger pressure (psi)
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
fatoni (04-17-2018), rvoll (04-17-2018), venturaII (04-17-2018)
Old 04-17-2018, 07:36 PM   #153
why?
why?'s Avatar
Drives: series.blue
How is that 100% false?
Because there are other factors. It is all about balance. You can have too much mechanical grip for a car to overcome. And that will absolutely slow a car down. Because grip=friction. Now if the car has a massive engine and can never get enough grip, that is one thing. But out cars have 200 hp, if that, to the wheels. And every bit of extra grip means the engine has to work harder to do everything.
Now maybe that is just a regurgitation of what you meant. It just felt like you were arguing that no matter what the wider the better, and all track cars should run as wide a tire as possible and the most aggressive aero they can possibly create.
The Following 2 Users Say Thank You to why? For This Useful Post:
rvoll (04-17-2018), Tcoat (04-17-2018)
Old 04-17-2018, 07:40 PM   #154
"DAMNIT FRED you put the body on backwards again!"
mrg666 (04-17-2018), strat61caster (04-17-2018)
What am I missing with all the ultra-wide wheels & tires? Vdub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-14-2017 09:08 AM
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 01:14 AM
Tires that run wide or narrow switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 12-08-2013 04:55 PM
I have a 18x7.5+38 wheels..How wide can i go with tires Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2013 01:04 PM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 09:38 AM
