Old 04-06-2018, 12:55 PM   #15
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
I just had my 2013 engine rebuilt with 62k under Toyota extended warranty, total bill was $11,602, the service agent told me that a new crated FRS engine was $6500. I was lucky Toyota did the right thing by honoring my warranty.
speedy racer is offline   Reply With Quote
Old 04-06-2018, 12:58 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
[QUOTE=spdsk8race;3068648]My big question is should I get it towed to another shop, since the dealership won't do a teardown to find the actual issue without a warranty, trust the dealership, or find my own engine which I have no idea where to start on that. Toyota told me because my oil records are from jiffy lube they are valid to a out of warranty fix. Only dealership records will be accepted.[/QUOTE]
Valid to out of warranty fix? What do you mean by that?
And like said, read your manual. You have a right to have the car serviced by anyone and you also do not have to use OEM parts/fluids.
https://www.consumer.ftc.gov/article...ne-maintenance
Old 04-06-2018, 01:16 PM   #17
speedy racer
I had oil changes from Jiffy lube and my local independent Honda shop beside me do oil changes at 7500 miles interval and Toyota honored my warranty. I believe you can do your own oil changes as long as you have all documents.
Old 04-06-2018, 08:12 PM   #18
spdsk8race
Drives: scion frs
[quote=finch1750;3068809]
They said they wouldn't do a out of warranty courtesy because it was serviced by jiffy lube. I talked the dealership today and told them I was going to be towing the car to a nearby shop who quoteed me 6k for a used engine 23k miles and labor with a one year warranty. They told me that they could possibly come under that. Which is a big difference from the 17k they originally stated.
spdsk8race is offline   Reply With Quote
Old 04-06-2018, 08:28 PM   #19
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Bought an engine with 15k miles for $2600 shipped. Labor will run you anywhere from 1-2k so you're at around $4k
shaynek is offline   Reply With Quote
Old 04-06-2018, 09:10 PM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
[quote=spdsk8race;3069046]
Run. Run far away and as soon as possible. That is beyond shady.
Seriously, get a second opinion.... you very likely could not even need an engine replacement, just a sensor. Did you take a look at the various fixes for that code by any chance?
The Following User Says Thank You to Summerwolf For This Useful Post:
humfrz (04-06-2018)
Old 04-07-2018, 08:58 AM   #21
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's a much better prospect already!
That said once your car is all better again, don't take it to Jiffy Lube or other 10-minute oil change places. The oil they use is shit, IF they even change it. They likely don't change your filter either. Do some googling, there are some horror stories out there. I'm not surprised the dealer refuses to own the warranty on a car serviced there.
Either take it to a good independent shop or do it yourself (it's really not hard and takes ~1/2 hour) if you don't feel like paying the dealership's price for an oil service. It's too important to leave up to chains that are known to take massive shortcuts at best.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
22R (04-07-2018)
Old 04-07-2018, 06:44 PM   #22
Decep
Drives: 2013 FR-S Series 10
I took my old 2000 Accord to Penzoil for oil changes from 40k to about 250k. Never had a problem with them. I did watch them do the work usually. They'd also always try to upsell all the other bullshit (air filters, trans flushes, coolant flushes etc) but that comes with the territory. Not all those places are bad.
I've since moved away and haven't found a decent similar place so i've been taking it to a independent shop and they charge damn near as much as the dealer for oil changes. And last time they installed a leaky bosch oil filter. might as well just go back to the dealer.
Old 04-11-2018, 03:23 PM   #23
robzz
Drives: Brz
For my personal knowledge, on the oil picture of OP, what does represents the metal flakes? Is it in the center of the light spot where there's sort of a color gradiant (brown towards grayish) or it's the bright white sparkles all around?
I had an oil change looking like the bright spot and I was concerned but also did'nt know what metal flake looks like.
thank and good luck to OP!
robzz is offline   Reply With Quote
Advice about dealership mishap! ModalSoul37 BRZ First-Gen (2012+) — General Topics 16 10-21-2014 08:30 PM
Dealership overfilled my engine oil mike the snake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-07-2013 11:50 PM
Need some advice (dealership error) Dreamshot Scion FR-S / Toyota 86 GT86 General Forum 19 06-09-2013 10:32 AM
Dealership advice MattZ28 Southeast 6 01-06-2013 02:36 PM
dealership 4 hours away, bad for engine break in? Mykflo BRZ First-Gen (2012+) — General Topics 27 05-23-2012 08:57 PM
