Old 03-20-2018, 10:54 PM   #1
Cal3000
Drives: Panda FR-S
AT 155k miles, everything wants to fail
I can't even drive the car a week now without something failing after I get a component fixed. lol.
OBDII doesn't work. My check engine light came on and my stock headers sound like unequal length. The power is still there.
Coil Pack?
Faulty DI?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-21-2018, 12:14 AM   #2
Cal3000
Drives: Panda FR-S
Ok, so I got a scan and it's a P000B, possibly the camshaft oil control valve bank 1 or timing chain. Where is bank 1 located? Left or right?
Old 03-21-2018, 12:24 AM   #3
I believe bank 1 is the one on the passenger side (for USA cars).
Right side as you're sitting in the car.
Left side as you're facing the front of the car.
The drivers side if you are in Japan.
(or do I have that backwards .....)
Cal3000 (03-24-2018)
Old 03-21-2018, 12:30 AM   #4
Decep
Drives: 2013 FR-S Series 10
Do timing chain tensioners need to be replaced on these cars eventually? hopefully its not a stretched chain.
Old 03-21-2018, 01:34 AM   #5
You need some diagnostic software to see if the valve timing moves at all. If P000B is the only DTC, is it out of time permanently, or just lazy?
What do you mean by "sounds UEL?" Is it running on 3? I know you said still has power but are you sure?
https://demos.starbase7.net/t3Portal...00XH80IWX.html
Old 03-22-2018, 06:59 PM   #6
reeves
Coil Pack?
Faulty DI?
I can't help with the diagnostics, but...
congrats on making it to 155K miles with that much power on stock internals!
The Following User Says Thank You to reeves For This Useful Post:
Old 03-24-2018, 03:24 PM   #7
Cal3000
Drives: Panda FR-S
Just got the OCV replaced and it seemed to fix the issue. I think it was what you said. The valve timing must have been really lazy. I was driving with the faulty OCV yesterday and would hold it at a rpm and the exhaust pulses would change the longer i held that constant rpm.
The UEL sound was from the out of spec exhaust opening angles from bank 1 which gave it the UEL header like pulse. When the car would go into limp mode correcting the discrepancy and it would sound normal.
With limp mode if you are boosted, it feels unsafe bc I think the fuel delivery values compared to compressor pressure are way out of wack along with everything else. lol
The Following 4 Users Say Thank You to Cal3000 For This Useful Post:
humfrz (03-24-2018), Spuds (03-25-2018), strat61caster (03-25-2018), Ultramaroon (03-24-2018)
Old 04-06-2018, 01:55 AM   #8
Cal3000
Drives: Panda FR-S
So the car is back at it again. The OCV replacement worked well for 1 week and now I got the same P000B code again along with P0014. Obnoxious. The car is running in limp mode now. The other 2 options now according to the repair manual is either the ECU or the OCV filter which is basically buried within the cam housing and looks like it requires the heads to come off to replace.
When the car is in limp mode, does it go back to a toned down stock tune? Or does it simply reduce timing? Is it safe to drive under boost?
Old 04-07-2018, 12:05 AM   #9
brianzlive
Drives: 2016 Scion FR-S
Crazy to see this much mileage this early that's like 240sx or 95 civic mileage haha. Good luck on getting her all fixed up though.
brianzlive is offline   Reply With Quote
Old 04-07-2018, 02:52 AM   #10
ermax
ermax's Avatar
I’ve got 240k miles on my 2002 IS300. But I also live in the largest city land mass wise in the US. Every commute I do is at least 30 mins. Go to the beach, 30mins. Take the kids to school, 30mins. Go to the mall, 30mins. Go to work, 1hour.
Old 04-07-2018, 08:09 AM   #11
Teseo
Drives: frs
I assume those miles arr highway, but gratz on keep it going amd reliable
Old 04-07-2018, 08:14 AM   #12
ermax
ermax's Avatar
Mostly city on that car. Our office moved sines getting my FRS so now my commute is all interstate but all stop and go. My data logs show an average speed of 30mph if I’m lucky.
BRZ Fail! Kuri BRZ First-Gen (2012+) — General Topics 14 09-21-2015 08:17 PM
FAIL! X3 paulca Other Vehicles & General Automotive Discussions 9 07-29-2014 06:27 PM
fail BRZPDX Northwest 24 11-21-2013 07:24 PM
Opticoat fail? VoiD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-25-2013 04:56 PM
If the FT-86 is a fail...what will you do? SteelReign Scion FR-S / Toyota 86 GT86 General Forum 172 04-28-2011 02:49 AM
