| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: 13 WRB BRZ
Opticoat fail?
I just noticed this today.. after heavy rain, in my work garage.
Got opticoat done in March, car has been parked in garage.. Is this sign of failure in just 7 months? i see no beading on roof/ front hood and bumper. Trunk still beads well.. do I need a new coat or is it even worth it? |
Drives: Raven M/T FR-S
Try washing it. I have had problems with that after going to the track, having it all dirty. After I washed it, came back to its normal beading awesomeness.
Drives: 13 WRB BRZ
Thank you.. will try that..
Drives: 2013 Whiteout FR-S
Subbed
Drives: Audi S4
please wash it like you would, I believe you should see some beading.
typically beading isn't one of the prominent features of opti coat. |
Paint Correction Guru
Drives: F150 Platinum
Spray down the entire car during the wash process with something like Optimum power clean 3:1. In the photos the paint looks dirty. Allow the cleaner to dwell on the paint and then rinse and re wash.
If it did fail it wasn't the coating, it was the application of the coating. Your installer should re install then. Cheers, GREG
"Detailing for the discerning owner" Meguiars/Ford detailing team SEMA 2010 and 2011 Ask a pro blog writer for detailed image duPont Registry approved detailer |
Drives: BRZ sold
Are you applying wax and how long has it been that you applied Iron X? There were post before that you just need to remove the wax and other bits so the OC can do it's job.
Drives: Dirty
Get some advise from your installer. The car/paint looks dirty and might need a good cleaning depending on the build up that may be on it.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit |
Drives: 2010 Corolla, 2013 Fr-s
The reflection on the paint suggest that the pain might be dirty.
Do you wash the car on regular bassis? Have you try to apply something over the opti-coat? If the top two has been yes.. you might want to try light claying a small portion of the car and see if it helps. Opti-coat should not fail that fast. I got mine done at about the same time as you, I park in an underground garage and outside from time to time, the coat is still functioning as when I first got it applied. |
| Hella Fail | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 117 | 01-14-2013 11:59 AM |
| BRZ to be AWD, straight from SOA (fail) | Laika | BRZ First-Gen (2012+) — General Topics | 22 | 03-05-2012 10:09 AM |
| presidential fail | RRnold | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-23-2011 07:54 PM |
| If the FT-86 is a fail...what will you do? | SteelReign | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 04-28-2011 02:49 AM |
