| Software Tuning Discuss all software tuning topics. |
OFT e85 tune question
was watching youtube video on flashing e85 OFT tune, it says wait until fuel light comes on and then add in some e85 and then drive around with the current petro tune while monitor the ST and LT fuel trims to rise. only flash the e85 tune when ST and LT fuel trims rise up to certain level. can anyone confirm this? and exactly what level those fuel trims supposed to be before i can flash the e85 tune?
#2 |
Drives: 2013 frs red
The car will run e85 with a gas tune (albeit shitty) but vice versa could be harmful to engine.
#3 |
#4 |
found this thread and it suggests the same as the youtube video, leave petro tune in after fill up with e85 for the first time and monitor the fuel trims.
http://www.ft86club.com/forums/showthread.php?t=67310
| The Following User Says Thank You to stlgrym3 For This Useful Post: | Tristor (04-06-2018) |
#5 |
Huge E85 fan!
Drives: 2016 Scion FRS
When the STFT started to go way up to 20, I pulled into a CVS parking lot and flashed the E85 tune. Then I drove easy for about 20 miles and watched fuel trims. I didn't do a pull for about another 50 miles. Basically you want to get the E85 into the fuel system and into the engine THEN flash and don't want to stress the engine until the LTFT are learned. Get the tank as low as possible on regular gas and fill up with E85. The E85 OFT tune is very forgiving of various %s of ethanol so a gallon of gas left in the tank is no big deal at all. Stylgrm3 post above is right on.
| The Following User Says Thank You to guybo For This Useful Post: | Tristor (04-06-2018) |
#6 |
The idea is not to switch to e85 tune til you're burning e85. E85 tunes have much more aggressive timing than gas tunes.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Tristor (04-06-2018) |
#7 |
Really debating whether to go with e85 tune, its free hp gain, but I’m concerning the car wasn’t designed to use e85, will switching the fuel cause long term damage to the fuel system and/or motor?
#8 | |
Drives: 2013 WRB BRZ
http://www.ft86club.com/forums/showthread.php?t=113819 http://www.ft86club.com/forums/showthread.php?t=115529 http://www.ft86club.com/forums/showthread.php?t=124769
#9 |
Drives: 2013 Scion FRS
As stated above, many people have run it for many miles and have been fine. However, if you’d rather be safe than sorry, just get a flex fuel kit to compensate for all the different ethanol percentages.
I’m actually going to try the E85 tune next week with the OFT since I’m confident from reading up that the car will be ok for my purposes (DD, no track use). There’s always a risk when modding your car, how much of a risk and if it’s worth the risk is subjective though. Be careful and good luck
#10 |
Drives: 2014 BRZ Limited.
I was a bit nervous to switch at first but been running E85 for months. No issues and real Nice power boost.
#11 |
alright, i think i'm gonna give it a try, just loaded both stage2+ e85 and regular stage2+ onto my tablet, i will flip a coin after i install my header to see which one i will pick lol
#12 |
If you fill up with E85, then install header, then switch tunes you’ll be shocked at the difference.
#13 |
are you suggesting to do the stage2+ e85 tune first on stock header and then install the header? no need to do another tune since stage2+ with e85 covers them all.
#14 |
Drives: frs
Im on stock headers and using stage2+ e85 which happens to be the only e85 file (v4). Running just fine since v4 was released. Previously running v2 EL stage 2 e85 for months. Now finally getting a header on wednesday.
IF all goes to plan ill see a difference which is what i want. Cant do much na, but doing each in steps feeling the difference after each adjustment is nice
| The Following User Says Thank You to Totalrecall For This Useful Post: | stlgrym3 (04-07-2018) |
| OFT E-tune question | Jarred55 | Software Tuning | 3 | 11-30-2017 09:10 PM |
| OFT TUNE QUESTION | Fish Head | Software Tuning | 4 | 03-19-2016 02:43 AM |
| OFT tune question | Harry04 | Software Tuning | 7 | 06-23-2015 11:47 AM |
| Tune noob with OFT question | Tectoniic | Software Tuning | 1 | 05-22-2015 07:26 PM |
| Newbie question: what is an ecu tune | Dispect | Engine, Exhaust, Transmission | 1 | 11-30-2012 01:35 PM |
