#365 | |
Drives: 2014 FR-S MT
For some reason, after installing the header and tune, I was slipping the clutch a lot more than previously from stop lights. Maybe it was the filled-in torque curve, but I was having the hardest time being able to feel where the clutch was biting. I've been driving manual for 30 years, and when the car was stock I thought the clutch was on the light side but ok in feel. After the header and tune I was slipping the clutch a lot more than I intended to. This mod really restored the drivability of the clutch. Thanks a lot for sharing it with us! |
| The Following User Says Thank You to H1C For This Useful Post: | Ultramaroon (12-09-2017) |
#366 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | H1C (12-09-2017) |
#367 |
#368 |
Drives: swp mt '14 brz premium
| The Following User Says Thank You to jcw99 For This Useful Post: | Ultramaroon (12-10-2017) |
#369 |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
Just finished the swap today. Best mod for this car without a question. Makes a huge difference in the drivability of the car. Worth every penny. Thanks for the info !!
| The Following User Says Thank You to chickunfut For This Useful Post: | Ultramaroon (01-27-2018) |
#370 |
Drives: Scion FR-S Ultramarine, Triumph STR
Finally gave this slave cylinder swap a try after owning the car for several years (prompted by driving my gf's Cooper GP which has a stiffer clutch pedal). Thanks very much for the suggestion and walk-through, this is one of my favorite mods for sure! Initial impressions are; much more predictable engagement point, shorter overall pedal travel, and slightly stiffer pedal feel. The swap took about a half hour and that's only because I decided to completely change out the old brake fluid. Parts were sourced from subaruonlineparts.com
| The Following 2 Users Say Thank You to PA-86 For This Useful Post: | funwheeldrive (04-12-2018), Ultramaroon (03-24-2018) |
#371 | |
With over 40 Kmiles of daily stop-&-go commuting, my clutch cylinders continue to work flawlessly.
#372 |
I'm almost at 50k miles, just recently cooked a coil pack. Only clutch related issue I've been experiencing is a squeaky/stiff feel in the clutch pedal when I get to the last inch or so of travel. Not at all related to the slave install, by the way.
| The Following User Says Thank You to PA-86 For This Useful Post: | Ultramaroon (03-26-2018) |
#373 | |
#374 |
Drives: 2017 BRZ WR Blue
I still need to do this at some point...
| The Following User Says Thank You to HSUBLU For This Useful Post: | funwheeldrive (04-12-2018) |
#375 |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#376 |
Drives:
Has anybody put a speed bleeder on this? Is it the same size as the original slave's bleed screw?
Sent from my SM-G930W8 using Tapatalk |
#377 |
#378 |
It's just plumbing. If you can fix a faucet, this'll be a cakewalk. Cleanliness is the key factor.
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 06:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 08:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 01:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 05:32 PM |
