Old 03-08-2018, 12:47 PM   #99
BRX
BRX's Avatar
Drives: Toyota GT86
Originally Posted by djezlee View Post
How do you guys like this kit when considering the heat it brings? I want to buy this ASAP, but I will have big time buyers remorse if it cant support my commutes. I drive on the German Autobahn (avg 95-120 mph for 2 hours at a time/ 4 times a month). I already had oil temp problems on a stock engine in the winter. So I just purchased the JR dual radiator/oil cooler. Do you guys think I will have heat problems with this kit?
To put it simply, yes. There are a few things you can do to make it work.
A lower temp thermostat (not mishimoto).
Remove the lower engine cover (if you do, remove the one behind it too) or get a baffled one.
Water wetter with distilled water as a coolant.
Tune the fans to come on earlier to work with the thermostat.
The fans and the thermostat won't help much once you start to build heat and driving at high speeds. But it will give you a cooler engine when you start your trip and cools down more when you let off or slow down in traffic.
From my experience if the outside temp is less than or around 30c you should be fine at 100mph. At 40c you might run a bit hot but not over heat. With a stock short block I wouldn't push it if the coolant temp gets to about 95c. That's how I blew my first engine
Sent from my Pixel 2 XL using Tapatalk
BRX is offline   Reply With Quote
The Following User Says Thank You to BRX For This Useful Post:
djezlee (03-09-2018)
Old 03-08-2018, 01:35 PM   #100
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Not if you live somewhere that freezes in the winter.
Trueweltall is offline   Reply With Quote
Old 03-08-2018, 02:39 PM   #101
CSG Mike
CSG Mike's Avatar
I track it without heat issues.
CxG (03-09-2018)
Old 03-09-2018, 12:53 PM   #102
CxG
Drives: Pearl White '13 ZN6
You track this kit with the Jackson Racing oil cooler / radiator combo?
CxG is offline   Reply With Quote
Old 03-09-2018, 05:22 PM   #103
CSG Mike
CSG Mike's Avatar
Stock radiator, GReddy oil cooler.
Also a host of supporting mods.
CSG ceramic
DEI wrap
DEI turbo blanket
Trackspec Hood vents.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
CxG (03-14-2018), djezlee (03-09-2018), mrg666 (05-21-2018)
Old 03-09-2018, 09:06 PM   #104
djezlee
Drives: 2017 BRZ Limited
thanks for the info! sounds like I should be considering a supercharger no matter how much I would prefer to run this turbo setup. Last thing i want is to overheat my engine or oil a long way away from home. I think the autobahn has similar stress on the engine as compared to a track, because the germans won't let you sit in a lane with cruise control set at 80 mph for two hours.
djezlee is offline   Reply With Quote
The Following 2 Users Say Thank You to djezlee For This Useful Post:
BRX (03-10-2018), CxG (03-14-2018)
Old 05-07-2018, 10:37 AM   #105
valtore101
Drives: 2016 FR-S
CSG ceramic
DEI wrap
DEI turbo blanket
Do you have the GPP kit with the GTX2871 or the base kit with the T518?
valtore101 is offline   Reply With Quote
Old 05-07-2018, 03:33 PM   #106
CSG Mike
CSG Mike's Avatar
I have the T518Z kit.
PM me to order, especially if you want your kit prepped the way mine is.
Evil Rocky (05-07-2018)
Old 05-07-2018, 03:42 PM   #107
CSG Mike
CSG Mike's Avatar
Low line = 2017 baseline (205hp crank)
2nd line = wastegate, 91 octane (~310hp crank)
3rd line = wastegate, e70 (flex) (~370hp crank)
high line = 10.5psi at peak power, e70 (flex) (~450hp crank)
Due to the nature of the dyno, the graph doesn't accurately represent how quickly the setup actually spools; I boost within 0.3s of throttle input from being off throttle, and can have full boost well before 3000 RPM.
Also, note that this was with a stock front pipe, and stock exhaust!
CxG (05-08-2018), Evil Rocky (05-07-2018), mrg666 (05-21-2018)
Old 05-07-2018, 05:32 PM   #108
R2
I've been meaning to ask you, what sold you on this kit as compared to other kits on the market. Also, given your experience and respected opinions, how do you view the drivability of this on track as compared to other turbo kits or the popular supercharger options?
R2 is offline   Reply With Quote
Old 05-07-2018, 05:52 PM   #109
CSG Mike
CSG Mike's Avatar
A lot of kits on the market copy this kit, or use this kit as a basis for their kit, with minor alterations to make it "unique".
This kit is well engineered, with a carefully selected, properly sized turbo. Many other kits offer more "features" to attempt to boost their perceived value. Those "features", in reality, are not needed for most users, including myself.
Note the lack of a BOV. I don't have to re-spool from scratch every time I transition on-off-on throttle, and the turbo is strong enough to handle not having a BOV.
BRX (05-07-2018), CxG (05-08-2018), mrg666 (05-21-2018)
Old 05-07-2018, 06:09 PM   #110
Evil Rocky
Drives: FRS
What is done differently with your kit and the one sold?
Man those are amazing numbers!!
Evil Rocky is offline   Reply With Quote
Old 05-07-2018, 06:14 PM   #111
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Mike,
Are you using the base t518z turbo from like 2014? I currently have the T620z that I bought back in 2014, do you have an idea what the max boost these turbos can go up to?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 05-07-2018, 06:55 PM   #112
CSG Mike
CSG Mike's Avatar
Full CSG ceramic coating on the exhaust components and shields, + DEI wrap, + boost controller. The hardware itself is unchanged.
Greddy / Trust Turbo Kit (Video and Pictures) BPAuto Forced Induction 62 03-18-2016 07:04 AM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 03:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! NOTORIOUS.BRZ Forced Induction 17 07-29-2013 05:42 PM
