Old 03-07-2018, 09:44 AM   #15
ermax
ermax's Avatar
Yeah, how was the oil? Was it leaking or burning? Any idea what CALID (rom version) you were on?
Old 03-07-2018, 09:47 AM   #16
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
Originally Posted by 8RZ View Post
Was the oil level good?
Oil light never came on, but it was half quart low. I drive a lot highway miles pushing my engine hard but these cars are made to run at high RPMs. I do have my RPM limit t 7k. I just hope Toyota honor my warranty, that was the only reason I kept the car after having the CEL issue. Do anybody else on here that had CEL issue have engine failure?
speedy racer is offline   Reply With Quote
Old 03-07-2018, 09:52 AM   #17
"CEL issue" doesn't mean anything. What was the problem that caused the CEL?
The most common reason that warranty is denied is no proof of oil changes or inspection that shows low oil as the probable cause of failure. That is why everybody is asking about the oil level. If oil level was good and you can prove it was changed then the warranty should be no problem.
Old 03-07-2018, 09:52 AM   #18
ermax
ermax's Avatar
1/2qt low shouldn't lead to rod bearing failure. You will need to elaborate on what "CEL" issue you are referring to.
Old 03-07-2018, 09:57 AM   #19
Originally Posted by ermax View Post
1/2q low shouldn't lead to rod bearing failure. You will need to elaborate on what "CEL" issue you are referring to.
If it is the number 4 bearing then it is the common failure mode. Be willing to bet a tear down shows silicone chunks in the oil channels.
ajc209 (03-07-2018), nikitopo (03-07-2018)
Old 03-07-2018, 10:44 AM   #20
speedy racer
CEL
My 2013 was one those first FRS with the CEL issues with the ECU and Toyota gave me the factory 7 year warranty because I was concern about future problems down the road.
Old 03-07-2018, 10:55 AM   #21
This one?
http://www.ft86club.com/forums/attac...1&d=1378232133
tintumz22 (03-07-2018)
Old 03-07-2018, 12:08 PM   #22
Shibby
Drives: 2013 WRB BRZ
These are exactly what happened to my 2013 BRZ with 55k. I showed proof of proper oil level and oil change receipts. It was silicon blocking oil to bearing 4 but was most likely caused by a repair done by the dealership to fix the timing cover leak I was experiencing. Since I was able to prove that the car was taken care of, they didn't argue with me about warrantying the work. Just food for thought.
Shibby is offline   Reply With Quote
The Following User Says Thank You to Shibby For This Useful Post:
Tcoat (03-07-2018)
Old 03-07-2018, 12:24 PM   #23
ajc209
Drives: GT86 Cosworth
As Tcoat mentioned, RTV blocking the smaller oil feed is quite common.
ajc209 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
Tcoat (03-07-2018), tintumz22 (03-07-2018)
Old 03-07-2018, 01:31 PM   #24
To be clear it is a common failure mode on engines that blew a bearing not necessarily a common occurrence.
There are about 25 recorded cases (on this forum) of bearing failure and maybe 7 or 8 of those were known to be the plugged oil channels. Don't want everybody with a 13 to think the sky is falling when the known numbers are actually miniscule. Doesn't make thing better when you fall into that minority though.
86kahl (03-07-2018), ajc209 (03-07-2018), Dadhawk (03-08-2018), DAEMANO (03-07-2018), DandoX (03-07-2018), Leonardo (03-07-2018)
Old 03-07-2018, 02:16 PM   #25
ajc209
Lol yes common cause of spun bearings in a stock setup. Mines a 2012..
Sent from my SM-G935F using Tapatalk
Old 03-07-2018, 04:02 PM   #26
ajc209 (03-07-2018), DandoX (03-07-2018)
Old 03-07-2018, 06:32 PM   #27
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Man I'm sorry to here that bud. Just curious what oil brand/weight you where running and how many miles in-between the typical oil changes?
I'm pulling for ya that the dealership honors the warranty.
DandoX is offline   Reply With Quote
Old 03-08-2018, 08:05 AM   #28
BRZnut
Drives: BRZ DGM Limited
Sorry to hear. Keep us updated. Yes these engines are supposed to be able to be "pushed hard" as you state but they do fail because of oil starvation.(I wish Subaru would extend the warrantee on the 2013's because of the silicone issue blocking oil flow and fess up to the issue)
Engine failure! mackeye Engine, Exhaust, Transmission 24 01-30-2018 12:48 AM
Engine Failure (Bearing Rod 2) Incursion Issues | Warranty | Recalls / TSB 59 11-27-2014 03:17 PM
Engine failure - 38,000 miles Mr 286 Issues | Warranty | Recalls / TSB 217 10-05-2014 10:52 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 03:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
