#29 | |
Drives: 2015 Scion FRS 6MT (Asphalt)
I originally looked at PTuning’s 4-1, but I think I was a bit naive to want that header just because it made the most peak horsepower of all of the ones I’d seen. A header with a strong midrange that can hold torque down to redline without dropping off too bad would likely make the biggest difference in acceleration, as opposed to one that only makes torque at the higher RPM range (I think). However, I’ve seen some people that run a 4-1 header and use a shorter final drive ratio to give the car that added “torque” feel. Sent from my iPhone using Tapatalk |
#30 |
I can confirm that my 2017 with a ceramic coated Ace header and stock FP pulls on a lighter car (gutted 2013) that's catless with a Ptuning header.
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#31 |
Drives: 2013 Scion FRS
#32 |
Shawn Church. Peak power is super close to the Ace, on the two cars, but the ace pulls because it has more area under the curve.
It's a pretty definitive pull too, and the ptuning header car isn't slow; it pulls on s2ks in straight line. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#33 | |
Drives: 2015 BRZ Limited
![]() No, it doesn't have the acceleration of an 10 second car with just the header and tune, but it's definitely noticeable IMO. It gained so much more torque over stock. OP wanted feelings, which are opinionated, so I gave him my feelings from my experience.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following 2 Users Say Thank You to FunnyGopher For This Useful Post: | Hades (03-04-2018), NAEightySix (03-03-2018) |
#34 |
Drives: '15 BRZ RA
A 86/BRZ car with a changed header and a tune faster than a s2k on pulls? So how much do you gain now? 40-50hp? Ok!
#35 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Hades (03-04-2018), NAEightySix (03-03-2018) |
#36 |
Drives: UK GT86
Final drive differences perhaps?
.: Stealth 86 :.
#38 |
Drives: '15 BRZ RA
#39 |
Drives: 2013 frs red
The ace obviously works and the results will not be matched with tune, intake and tb. Oh and gutted cat. Get what you pay for.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | NAEightySix (03-03-2018) |
#40 |
Drives: '15 BRZ RA
Who said I am comparing with my car? I just don't like someone to say that you can get a +40-50 hp gain just with a header and a tune. It is unrealistic. If you go with E85, then yes you are much closer. However, if you want to do it right then you the need a flex fuel kit and be lucky enough to find always a gas station.
| The Following User Says Thank You to nikitopo For This Useful Post: | Trueweltall (03-04-2018) |
#41 |
Drives: UK GT86
So you put the older FD in the newer car?
.: Stealth 86 :.
#42 |
Drives: FT86
I came across this chap on YouTube - Justin's Pit Lane "Does the ACE A350 Header Live Up To The Hype!?!"
[ame="http://youtu.be/ggQspB1P7a4"]http://youtu.be/ggQspB1P7a4[/ame] He compared his Revworks header Vs the ACE A350 with dyno results. Oop's Justin himself has already posted this http://www.ft86club.com/forums/showthread.php?t=125559 |
| The Following User Says Thank You to vf34 For This Useful Post: | NAEightySix (03-03-2018) |
| jdl header / tune questions | dtrop | Engine, Exhaust, Transmission | 13 | 03-31-2016 04:40 PM |
| Header Gasket Questions | gepeyo | Northern California | 11 | 02-02-2015 11:51 PM |
| EL header questions | newports | Engine, Exhaust, Transmission | 2 | 03-29-2014 02:41 AM |
| Intake, Header, Exhaust questions | KillionsFRS | Engine, Exhaust, Transmission | 8 | 09-05-2013 11:12 PM |
| header tech questions and opinions | ft86me | Engine, Exhaust, Transmission | 7 | 04-01-2013 04:40 PM |
