Old 02-19-2018, 11:58 AM   #1
Q2
Drives: 2015 FRS Whiteout
SBD500x Spark Plugs?
Hey I'm having the SBD500x put on my 2015 Scion FRS When I called to make an appointment to get it tuned he recommended changing the spark plugs before the tune, would anyone have any recommendation as far as what would be the best spark plugs for it I see so many I don't know exactly what would be the best for it as this is sort of the last thing I want to do with the vehicle
Here's a list of what's done so far:
Fuel inj: https://www.maperformance.com/produc...-16u-02-0900-4
Fuel Pump: https://www.maperformance.com/produc...&isp_ref_pos=1
Clutch: http://www.ft86speedfactory.com/sout...aily-1764.html
Exhaust: http://www.ft86speedfactory.com/invi...l#.WornSBPwZTI
Down pipe: https://www.proimporttuners.com/part...bo-outlet.html
Turbo: https://spdbydesign.com/product/sbd5...-brzscion-frs/
I did get it with the optional pre welded oil pan
Over pipe + front pipe: https://spdbydesign.com/product/sbd-...ontpipe-combo/
Q2 is offline   Reply With Quote
The Following User Says Thank You to Q2 For This Useful Post:
ShadowReaper (02-19-2018)
Old 02-19-2018, 12:31 PM   #2
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Also interested in answers for this... Scott at RevWorks recommended Spark plugs as well
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 02-19-2018, 12:50 PM   #3
ExpertZero
Drives: FR-S 2015 Halo
I have hks super fire plugs in mine.
ExpertZero is offline   Reply With Quote
Old 02-19-2018, 01:28 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
As a general rule, anytime you go turbo or supercharge on an engine that's NA to begin with, you go one heat range colder on the spark plug.
ShadowReaper (03-18-2018)
Old 03-18-2018, 12:26 PM   #5
Ariel16
Drives: 2016 Subaru BRZ Premium
I'm also looking for this answer!
Ariel16 is offline   Reply With Quote
Old 03-19-2018, 08:07 PM   #6
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the stock plug is already very cold and there are many, many modified cars running around on them
Matt@Cosworth is offline   Reply With Quote
Old 03-20-2018, 07:56 PM   #7
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I never heard about this. I didn't do this on my SBD400x kit and I know a few guys who went thousands of miles on the stock plugs.
SUB-FT86 is offline   Reply With Quote
Old 03-26-2018, 09:30 AM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
They're likely requesting plugs be done to rule out something simple as a point of failure. I'm sure they'd rather be tuning your car than changing your crusty plugs. I'd stay oem unless otherwise specified.
Irace86.2.0 (03-26-2018)
Old 03-26-2018, 09:35 AM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
stock
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 02:06 AM
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 05:19 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
