Drives: 2015 FRS Whiteout
SBD500x Spark Plugs?
Hey I'm having the SBD500x put on my 2015 Scion FRS When I called to make an appointment to get it tuned he recommended changing the spark plugs before the tune, would anyone have any recommendation as far as what would be the best spark plugs for it I see so many I don't know exactly what would be the best for it as this is sort of the last thing I want to do with the vehicle
Here's a list of what's done so far: Fuel inj: https://www.maperformance.com/produc...-16u-02-0900-4 Fuel Pump: https://www.maperformance.com/produc...&isp_ref_pos=1 Clutch: http://www.ft86speedfactory.com/sout...aily-1764.html Exhaust: http://www.ft86speedfactory.com/invi...l#.WornSBPwZTI Down pipe: https://www.proimporttuners.com/part...bo-outlet.html Turbo: https://spdbydesign.com/product/sbd5...-brzscion-frs/ I did get it with the optional pre welded oil pan Over pipe + front pipe: https://spdbydesign.com/product/sbd-...ontpipe-combo/ |
| The Following User Says Thank You to Q2 For This Useful Post: | ShadowReaper (02-19-2018) |
#2 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Also interested in answers for this... Scott at RevWorks recommended Spark plugs as well
Instagram: Gabe.it.the.ole.college.try |
#3 |
Drives: FR-S 2015 Halo
I have hks super fire plugs in mine.
#4 |
Drives: 2005 Toyota Camry
As a general rule, anytime you go turbo or supercharge on an engine that's NA to begin with, you go one heat range colder on the spark plug.
| The Following User Says Thank You to mav1178 For This Useful Post: | ShadowReaper (03-18-2018) |
#5 |
Drives: 2016 Subaru BRZ Premium
I'm also looking for this answer!
#6 |
Drives: blue - Cosworth SC stage 3.0
the stock plug is already very cold and there are many, many modified cars running around on them
#7 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I never heard about this. I didn't do this on my SBD400x kit and I know a few guys who went thousands of miles on the stock plugs.
#8 |
Rust bucket enthusiast
They're likely requesting plugs be done to rule out something simple as a point of failure. I'm sure they'd rather be tuning your car than changing your crusty plugs. I'd stay oem unless otherwise specified.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Irace86.2.0 (03-26-2018) |
#9 |
Drives: 2JZ FRS
stock
| The Following User Says Thank You to spitfire481 For This Useful Post: | Irace86.2.0 (03-26-2018) |
| How to gap spark plugs | Strife26 | Engine, Exhaust, Transmission | 38 | 01-09-2018 02:06 AM |
| Spark Plugs at 65K | user4815 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 50 | 12-25-2017 05:19 PM |
| Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 11:47 AM |
| spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 12:24 PM |
