go_a_way1
Old 02-12-2018, 02:07 PM   #3655
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Fainten View Post
Hey Im trying to run 245/35 18 with a 9.5 rim but in stock height(for now) if i go with federal 245s 595 rs r would they fit good with no rubbing. I heard they run bigger
It depends on the offset of the wheels. Why those tires? Do you want a really soft tire that is not going to last very long?
Read post 213 and 214.
http://www.ft86club.com/forums/showt...=28017&page=16
Read page one of the Meaty tire thread.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 02-14-2018, 08:30 PM   #3656
juicyg6
juicyg6's Avatar
Drives: 2017 Toyota 86
Hi guys
I'm looking to make a big investment for wheels so I really want to get this right before I put down my hard earned cash.
I would like to purchase on of the wheels below:
1. Rays ZE40 Time attack edition
17x8.5 +43
2. Rays TE37 Saga
17x8.5 +45
I have a 2017 Toyota 86 on stock suspension. I will also most likely be purchasing a 245/40/17 tyre to suit based on what I've read here.
Will these wheels fit my car with rubbing issues? If so, how flush (or not flush) would it be?
Cheers
juicyg6 is offline   Reply With Quote
Old 02-15-2018, 06:55 PM   #3657
DarkSideFRS
Drives: 2013 pearl white FR-S
just test fitted 17x9 +38 57DRs and here's the clearance i have from the strut perch... i am lowered on TRD springs and running -1.7 camber up front
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Kami Speed (02-16-2018)
Old 02-15-2018, 06:57 PM   #3658
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
when you get them fully mounted post pics. im looking at 1" drop n 17x9 and wanna see your fitment
JustSomeGuy is offline   Reply With Quote
Old 02-15-2018, 07:45 PM   #3659
DarkSideFRS
+35 should be no issue... +38 will fit but you can't have aggressive camber... someone ran -1.3 camber on his 17x9 +38 and it fits
Old 02-16-2018, 03:38 PM   #3660
Tristor
Tristor's Avatar
So, I've done a ton of reading and quite a bit of math to go with it. I think I've figured out a safe upsize which will allow me to get wider wheels and tires without upsetting the stock suspension geometry or increasing scrub radius a significant amount. The wheels I'm planning to purchase at this point don't appear to be listed in any of the threads as something people have tried/confirmed fitment for, but the size is a match from some BBS wheels so I'm pretty confident about this. That said, it never hurts to ask the experts and verify first before I drop $3k on wheels.
2017 BRZ Limited, I'm planning to put Volk ZE40 Time Attack Edition 8Jx18 ET44 wheels mounted with Bridgestone Potenza S-04 Pole Positions 225/40R18 tires. If my calculations are correct the scrub radius should be positive compared to stock by less than 1mm and I should be able to clear the suspension components with these wheels/tires without a problem.
Can someone confirm fitment for above: 8Jx18ET44 225/40R18?
Also, any opinions on the plastic hub centric rings from hubcentric-rings.com? Looks like I'll need a 65.0mm to 56.1mm ring for a perfect fitment to the wheel hub on a BRZ.
I'm also split between getting the McGard splinedrive lug nuts and getting the matching Rays Dura-Nut lug nuts. Any thoughts?
Tristor is offline   Reply With Quote
Old 02-16-2018, 03:52 PM   #3661
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8 +44 will fit perfectly with 225/40 tires. Volk wheels are awesome! (and expensive) S0-4's are good tires too.
Plastic hub rings work perfectly. They also wear out over time compared to a metal rings. (it still takes many wheel on/off cycles)
I LIKE TIRES!
Tristor (02-21-2018)
Old 02-16-2018, 04:41 PM   #3662
Fever
Drives: '13FR-S Ultramarine 6MT
Shopping for wheels and thought I'd run the numbers here to double check.
1. 17 x 8.25 32mm offset
2. 18 x 8.5 30mm offset
Stock suspension, either 225 or 235 wide tires. Any problems with either of these sizes? I figure the 17" size is no problem, more concerned about that 30mm offset on the 18x8.5
Thanks
Fever is offline   Reply With Quote
Old 02-16-2018, 05:38 PM   #3663
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by juicyg6 View Post
Hi guys
17x8.5 +43
2. Rays TE37 Saga
17x8.5 +45
Cheers
Great choices!!! Both will fit no problem. 2mm difference is so little. They would practically look the same.
The stock 17x7 takes up to a 25mm front spacer to be flush. the 17x8.5 +45 will be 22.1 mm farther out than the stock wheel. This means both +43 and +45 offset will look flush. And you will have enough inner clearence to use springs and camber bolts. (if you choose to)
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
eMCee (11-09-2018), juicyg6 (02-21-2018)
Old 02-16-2018, 05:48 PM   #3664
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks
17s will work and look flush. You will want some camber bolts for both 17or 18.
18s will work too, with 225/40 tires. but will poke 10mm + or so in the front. 18x8.5 +30 has almost exactly the same poke as a 18x9+35; which is a popular size.
I LIKE TIRES!
Fever (02-16-2018)
Old 02-16-2018, 05:49 PM   #3665
Tristor
Tristor's Avatar
Thanks, I appreciate the confirmation. Yeah these are some pricey wheels. Any thoughts on which locking lug nuts I should get?
I know I can't make it impossible for the wheels to steal, but I'd like to do something. My car is garaged and I live in a good neighborhood, but I'm sometimes parking in garages downtown and at the mall where someone could probably take off with them pretty easily, and it unfortunately does happen in this area.
Cheers!
Old 02-16-2018, 06:06 PM   #3666
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Cheers!
IDK what lug nuts to suggest. I have a set of gorilla locking nuts. Steel, reliable, inexpensive.
Volks, are out of my price range. But, If I was going to buy volks, I would think about buying a set of volk lug nuts.
I LIKE TIRES!
Old 02-17-2018, 05:32 PM   #3667
Greenbean
Drives: 2017 series yellow BRZ
255/35r18
Im sure this was answered somewhere but its alot of pages in this thread. Im going to get option labs r716 18x9.5 +35 and i want to run square with tires and i want 255/35 im just wondering if that will rub on full lock up front? if so i can go with 245s. I will be installing fortune auto coilovers the same time i get these wheels.
Greenbean is offline   Reply With Quote
Old 02-18-2018, 12:24 AM   #3668
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
what's the spacer requirement to clear 18x9.5 +40 enkei nt03+m on the performance package brembos?
spicyricecake is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
