Old 02-10-2018, 11:27 PM   #15
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by cyde01 View Post
I suggest a lav mic. If you use a shotgun mic, get a mic stand and place it much closer to your mouth. Don't leave it mounted on the camera when you're standing extremely far away from the camera! You'll get bad audio and hear all the reverberation from being in your garage.
Yea that's what I'll use more often in scenes like that. I have the lav mic just never use it in the garage before. Thanks!
justinco is offline   Reply With Quote
Old 02-14-2018, 11:51 PM   #16
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Just as a heads up for the ACE header install. I went to tighten down the bolts today after driving on it a bit and noticed that the bottom of the header was very slightly hitting the under tray. Just took a couple wacks to the tray with a hammer and that took care of it.
The Following 2 Users Say Thank You to justinco For This Useful Post:
CSG Mike (02-15-2018), strat61caster (02-15-2018)
Old 02-15-2018, 12:11 AM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
That's a known issue, right?
Sent from my SM-G950U using Tapatalk
Old 02-15-2018, 12:14 AM   #18
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I think so, yes. But I didn't remember when doing the install and just noticed today.
Old 02-15-2018, 12:34 AM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
Regardless, glad it was an easy fix. BFH FTW. Every man's favorite tool.
The Following User Says Thank You to Pat For This Useful Post:
Old 02-15-2018, 01:57 AM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Certain chassis you need a hammer at the ready, other chassis require an angle grinder, others a welder.
The 86 so far seems like the kind of car that responds best to a hammer.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (02-15-2018), johl (02-15-2018)
Old 02-15-2018, 03:12 PM   #21
Chamaco
Drives: Silver FR-S
Need to do this to mine.
Chamaco is offline   Reply With Quote
Old 02-15-2018, 03:15 PM   #22
toast
Drives: 14 BSP Edelbrock BRZ
Why not use the hammer on the header?
<ducking>
toast is offline   Reply With Quote
Old 02-15-2018, 04:23 PM   #23
CSG Mike
CSG Mike's Avatar
Sure is!
Stiff/solid engine mounts eliminates it, as the clearance is only a few mm; the OEM engine mounts and softer engine mounts allow enough flex for the header to touch the undertray
@justinco may have noticed the ceramic is much harder than that undertray
gtengr (02-16-2018), justinco (02-15-2018)
Old 02-15-2018, 04:35 PM   #24
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Sure is!
Yea, this ceramic is on another level. I've had all kinds of parts ceramic coated over the years (turbo manifolds, turbines, downpipes, other headers, etc) and this stuff looks like new even after some use.
Old 02-15-2018, 06:45 PM   #25
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
just a heads up for anyone that will do this in the future, use a ballpeen hammer from this not a claw hammer. it will be a lot easier.
Old 02-15-2018, 07:42 PM   #26
new2subaru
Weight Weenie
Drives: 15 FR-S
They look to be the size of a silver dollar (Twoonie for the Canucks) You could probably beat it with a rock
Old 02-16-2018, 04:51 PM   #27
Sachmet43
Drives: 2015 FR-S
Thanks for the great video
It's pretty simple! And like jasono said, tuning is pretty idiot proof these days, but I can see it being confusing for someone who has not done it before. Stay tuned for a video on ECUtek basics in the near future
I'll look forward to this one!
Sachmet43 is offline   Reply With Quote
The Following User Says Thank You to Sachmet43 For This Useful Post:
justinco (02-16-2018)
Old 02-16-2018, 06:30 PM   #28
gtengr
Drives: 2017 BRZ
Sure is!
Yep. I'm not sure if the CS400 are routed any differently than the A350 with regard to the pan clearance, but I didn't clearance the pan when I installed a CS400 plus sti engine and trans mounts, and can confirm that there are no rattling sounds or apparent issues.
gtengr is offline   Reply With Quote
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-26-2016 12:06 AM
Stock NA Tune - Motoeast or Delicious Tuning? brillo Software Tuning 9 11-23-2015 01:48 AM
Stock NA tune - MotoEast or Delicious? brillo Software Tuning 2 11-21-2015 11:45 AM
Delicious Tuning is the way to go for a custom tune. Canivideo User/Vendor/Sponsor Reviews, Feedback, Comments 5 01-13-2015 04:47 PM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
