Old 02-07-2017, 01:33 PM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
I'd have nothing wrong with brake squeel on track. Funnily that's the place one can bed in even most track-ish pads .
But i wouldn't want squeel on daily driving. Maybe other drivers on the road don't mind as much as i think they do, but at least i feel like idiot stopping with loud squeel near them at stoplights or squeeling madly on every small stop when moving in traffic jams. And daily driving is what 99% of my milleage is made of. So certainly i mind squeeling in general, ease of bedding pads when daily driving, and as due being too lazy and using same pads on both DD & track, am willing to give up some of 1% track-only performance to keep ability to DD bed. For me track days are more for fun, not competition anyway. If i'll ever follow further down rabbithole and will become more of a track junkie, most probably will need to go pad-swap route, to get both performance & reasonable daily driving properties. As it seems, there are no ideal pads that will fit best for all usage cases, every is compromise of sorts and one just have to choose his own poison depending on priorities .. or swap between sets.
Old 02-07-2017, 09:53 PM   #30
ajh88
Drives: 2013 Firestorm FR-S
Haha TBH I'm with you guys, I don't care that much about the squealing and chirping but was worried it it might have been a larger problem with the pads. Once I put on the GS1 I didn't need to go back to the R12/10.0 Also wanted to keep the R12/10 'track only' to keep better tabs on their wear.
Squealing is cosmetic. I dont think the rotational chirping was good for the brake system though.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 02-07-2017, 11:41 PM   #31
ryoma
ryoma's Avatar
I get chirping after my pads warm up when driving (while not on the brakes), especially when it's bumpy. I already lubed the slider pins with 3M silicone lube and used a wire brush to clean off the brackets that the pads slide in to. the chirping is still there though... gonna take another look at it soon and see what else I can do. I'm thinking it has to be that bracket since the caliper slides easily and freely.
Old 02-08-2017, 01:03 AM   #32
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Icecreamtruk View Post
All the people here complaining about squeals. Is there anything wrong with letting them squeal? You go thru the trouble of bedding them (using up more pad material and heating up the rotors) just to have them go back to squealing a few days later? I stopped bedding in my pads, I havent had problems since, other than they are obnoxiously loud, except after a track day, where they are quiet for a good 2-3 days.
Yep. Same here, just let them be. I did start to brake hard at stops and it helps. At least when the other half isnt in the car. She doesnt appreciate the slight abruptness lol
Old 07-23-2017, 12:51 AM   #33
KL
Drives: 2013 SWP BRZ
@drewbot any update on your rotational noise?
I'm trying to troubleshoot a similar squeal on my HC+800s; rotational squeal at low speeds when coasting/light throttle. Already had pads cleaned and caliper wire brushed and re-lubed (even sanded the lip off my rotor edges) by a dealership tech and that only solved the noise for a week or two. I dgaf about squeal but I'm worried about dragging the rears like CSG Mike suggested (fronts are and always have been dead quiet). Slide pins are the next thing on my list to check. Maybe check/clean pistons and boots too? *shrug*
Just wondering if you had any more info towards a resolution instead of making another goddamn "my brakes are squealing" thread.
Sent from my Pixel using Tapatalk
KL is offline   Reply With Quote
Old 02-14-2018, 02:26 PM   #34
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
LOL necro post sorry bro. Thing still squeals like before but because the pad thickness is getting less with more track days, the rotational chirping/chatter is reduced. I think the pad I got just fit tight and with heat everything expands/contracts at different rates.
drewbot is offline   Reply With Quote
Brake Squeal Maritime Storm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-01-2015 11:59 AM
How much benefit are lighter wheels rotational mass wise Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-05-2015 09:34 AM
No squeal pads for AP Racing Essex Sprint Kit Hags86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 04-04-2014 04:53 PM
Blower fan squeal 2point0 Issues | Warranty | Recalls / TSB 4 04-01-2014 08:40 PM
No Squeal Track Pad? gbgracer Tracking / Autocross / HPDE / Drifting 15 03-27-2013 09:21 PM
