#29 | |
The Dictater
Drives: '13 Red Scion FRS
OP, If this is different than before the accident, bring it back to the shop that did the repairs and tell them they missed something. I'm assuming insurance took care of that bill? If it wasn't fully repaired that's a problem for them to fix. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Summerwolf (02-06-2018), Ultramaroon (02-10-2018) |
#30 |
Panda Trueno
Drives: No twin now.
Well, to get something in to specs using a crash bolt means something else wouldn't come back in line 100%. It can still be considered a good repair, but obviously something is messed up.
What kind of measurements did they take during repair? Did they check the front subframe and make sure the strut towers were true? What was actually fixed during the repair and what was the extent of damage? You said "slight" suspension damage, but it is very easy to miss things or do shoddy repairs, especially when trying to fix it as cheap as possible. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | Tcoat (02-07-2018) |
#31 |
Panda Trueno
Dude.... looking at your posts, airbags, door, fenders, seat and abs/ traction control problems. Is this a totalled car you're rebuilding? Or did you total it and buy it back / doing repairs yourself?
| The Following 5 Users Say Thank You to Summerwolf For This Useful Post: | Cole (02-06-2018), Impureclient (02-06-2018), Spuds (02-06-2018), Tcoat (02-07-2018), Ultramaroon (02-10-2018) |
#32 | |
The Dictater
http://www.ft86club.com/forums/showthread.php?t=124468 I'm all for helping a guy out, but I'd recommend letting us know what we are dealing with here so we don't waste ours and your time barking up the wrong tree. |
| The Following 5 Users Say Thank You to Spuds For This Useful Post: | Brayden_23 (02-07-2018), Cole (02-06-2018), humfrz (02-06-2018), Riftur (02-07-2018), Ultramaroon (02-10-2018) |
#33 | |
Drives: 2014 brz limited
#34 | |
DANG! ....... so, we get "the rest of the story" ...... you get a light for that ....... ![]() Maybe the frame is bent or is wonky. I'd suggest you take it to a frame shop to see what they have to say. humfrz |
#35 |
Panda Trueno
What was actually fixed during the repair and what was the extent of damage? You said "slight" suspension damage, but it is very easy to miss things or do shoddy repairs, especially when trying to fix it as cheap as possible. I'll ask again, since I am genuinely curious. I also noticed your caster is off a degree less on the drivers side, that could possibly indicate a control arm issue. I said possibly. |
#36 | |
The Dictater
I agree with @Summerwolf , you are likely looking at a control arm (or sway bar) issue if you are lucky. If you are unlucky it's probably a frame or upper mount issue. Are you braking on the off ramps? In addition to a front suspension issue, there's a small possibility of a brake bias issue. I say that because that's also where the brake hydraulics are. It doesn't try to pull to one side or do anything funny when you press the brake pedal does it? |
| The Following User Says Thank You to Spuds For This Useful Post: | Summerwolf (02-10-2018) |
#37 | |
#38 | |
#39 | ||
Even using the bolt they still have not got it into spec really. There is something more severe that using a crash bolt just isn't going to correct.
#40 |
Judging by everything I have read. It could be so many things causing this issue we could talk about it for days. Only thing you can do is a process of elimination. Measure one thing and keep going till you find it.
| The Following 3 Users Say Thank You to Riftur For This Useful Post: |
#41 |
With the little info we have I am still putting my money on a tweaked sub frame that instead of being properly straightened was just adjusted with a bolt. Of course as you said there are many, many possibilities but this is my armchair diagnosis.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (02-07-2018) |
#42 |
Drives: AP1 Honda S2000, Focus RS
I stand by my earlier statement that the rear is not fully in alignment, Iv'e been down this road just trying to save you some time.
I pretty much knew you were dealing with a damaged vehicle from the original post. If someone comes back to you and tells you it is in alignment and your car is behaving in this manner, they don't have the tools to let you know what is actually happening. Don't confuse me saying Alignment, with the service people offer called an alignment. That service is for vehicles that are relatively true to spec, a salvaged vehicle will take some real work. |
| The Following 6 Users Say Thank You to deejaylew For This Useful Post: | Crashdummy (02-07-2018), humfrz (02-07-2018), NAEightySix (02-07-2018), Spuds (02-07-2018), Summerwolf (02-07-2018), Tcoat (02-07-2018) |
| Car swaying left right (floating feeling) highway speeds | FX86 | Issues | Warranty | Recalls / TSB | 37 | 05-30-2021 11:48 AM |
| Hood lift at high speeds | Basti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 97 | 02-15-2016 03:50 PM |
| weird issue at high speeds after OFT tune | dejxx | Software Tuning | 24 | 08-10-2014 09:49 PM |
| feeling a sway on the rear end | qganja | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-25-2013 03:56 PM |
| High pitch sound at freeway speeds | l0aded | Issues | Warranty | Recalls / TSB | 7 | 06-14-2013 05:25 AM |
